CanApi4 with older PCAN drivers
CAN Development Packages for Windows®
Murat.Ocakturk
Post by Murat.Ocakturk » Tue 18. Oct 2016, 08:54
I started to use PCAN developer 4 using my own C# wrapper. It is working successfully with old PEAK hardwares as well as PCAN USB FD. Everything seems good in my PC.
However, my application didn't work on my friend's PC which has older PCAN driver. "GetParam" function returns "driver not loaded" error when trying to request driver version (ERR_NODRIVER).
I'm using "pcan_usb" device type.
CanApi2 works OK in friend's PC.
Driver in PC-1: "PCAN_USB 4.1.0.16057 (KMDF, x64)" --> CanApi2 and CanApi4 works OK here.
Driver in PC-2: "PCAN_USB 3.8.2.10146 (KMDF, WLH_amd64)" --> CanApi2 is OK, but CanApi4 does not work.
Murat
Re: CanApi4 with older PCAN drivers
Post by K.Wagner » Tue 18. Oct 2016, 09:22
the CanApi4 works wiht the drivers 4.x. Drivers 3.x and 4.x have different interfaces. Please update the drivers on the second computer. The drivers 4.x also support old hardware (backward compatibility).
