VC2005 - always CAN_ERR_QRCVEMPTY
I have the following problem:
We developped a CAN simualation. It sends and received CAN messages incl. UDS diagnostic messages.
I am using VC2005 MFC, because it is a very old project. The driver and api versions are:
peakcan.sys: 2.49.14.4542
pcan_usb.sys: 3.8.2.10146
If I build my application in debug mode, everything is working fine. I can read and send CAN messages.
If I build my application as "Release", the receive method CAN_Read always replies with
CAN_ERR_QRCVEMPTY 0x0020.
In this case I can send messages, but can not receive any.
Could you help here?
Thank you and kind regards
Berthold
Berthold
Re: VC2005 - always CAN_ERR_QRCVEMPTY
which version of the canapi2.dll do you use?
I use 2.56.2.0
Berthold
I use 2.56.2.0
Berthold
it is the latest version. Please check with PCAN-Status Display the settings of your filter code and mask register. Maybe it will also be helpfull to contact us by phone to discuss that problem. Must be something wrong in your application.
Michael Maidhof
Michael Maidhof
it was the Client filter. I did not set the filter and this was the problem.
After adding the function CAN_SetClientFilter to the initialization sequence, everything
works fine.
Thank you for the hint
Kind regards
Berthold
works fine.
Kind regards
Berthold
thanks for the feedback. You could also use the CAN_RegisterMsg() API to open the filters in an user friendly way (message ID based).
