Find CAN Baudrate.
Find CAN Baudrate.
I have a project in C# which use CANApi2 with two PCAN module.
I want to know if it's possible to get the baudrate of the CAN bus which is connect to the PCAN.
I mean that I configure the Can connection (ID, net , ...) and open it. And on this connection, I want to get with a function all baudrate of the current CAN connected.
Is it possible?
Have you an idea for do that?
Thank.
Is it possible?
Thank.
Re: Find CAN Baudrate.
Yes, that is possible. In the CANAPI2 you use Client & Net Handles. The Baudrate is a Property of the Net Handle.
Simply use the GetParam(...) function with the PARAM_BAUDRATE parameter, and you get back the Baudrate as BTR0BTR1-Code (which is simply to compare with the defined Baudrates)
Thanks for your reply but it's not exactly what I want.
I want to detect the baudrate of the CAN bus on which I'm connected.
I don't want to get the baudrate of the with GetParam() function because it's the baudrate that I set it.
Do you understand what I want?
HowTo find the BUS Baudrate without influence the CAN Bus:
- Be sure that minimum 2 other CAN nodes are communicate on the CAN Network (they must be "active")
- Set you CAN Interface from PEAK-System to listen only mode
- Set the Baud rate and listen on the Bus (there must be traffic on the bus)
- Check CANRead Value and see if you receive a valid CAN Frame - if yes - you got it - if not change to next baud rate and read again.
- Run until end of available Baud rate list or until you found the Baud rate.
Thank you.
But how you cans check if the receive frame is valid or not? Have you a function to do that? Because I check the MsgType of the CANApi2.TCANMsg and if it's not 0 or 2 it's not a valid CAN frame.
And another question. How can I put my CAN interface in listen only mode with CANapi2 function?
If you read a real CAN Frame - the Baudrate/BTR0/BTR1 Values are valid ! If the Baudrate is wrong you will never see a valid CAN Frame on the bus - very easy...
The CANAPI2 is a non free Development Tool. Please send serial number and company information to our support[at]peak-system.com email and we could send you a sample.
