different symbols on the same can-id
tuttoaldoc
Post by tuttoaldoc » Wed 21. Oct 2020, 14:55
I fastly searched on the forum but I didn't find any argument similar. If I try to define 2 symbols on the same can-id symbol editor gives me an error: is it possible to do that? I'm monitor 2 different can busses where the same can-id is used.
Michele
Re: different symbols on the same can-id
Post by M.Heidemann » Wed 21. Oct 2020, 15:16
Symbols need to be unique within a symbol file.
However, if you are using two CAN-buses at the same time, you can also work with two independent connections and assign a different symbol to each of them.
This way you can assign two different symbols to the same ID.
tuttoaldoc
Post by tuttoaldoc » Wed 21. Oct 2020, 15:25
thank you very much, I didn't notice it
Michele
