Hallo,
I attached the files and also added screen-shots that show the data on the bus using a monitoring software.
thanks for your help
Katharina
transmitest und receivetest not working
Re: transmitest und receivetest not working
pcanfdtst_tx_100.txt
- pcantdtst
- (133 Bytes) Downloaded 575 times
pcan_2.txt
- pcan2
- (473 Bytes) Downloaded 557 times
pcan_1.txt
- pcan1
- (473 Bytes) Downloaded 531 times
- Data
- screenshot Daten.PNG (43.1 KiB) Viewed 5048 times
- Datarate
- screenshot Baud.PNG (5.62 KiB) Viewed 5048 times
- S.Grosjean
- Software Development
Thanks but I think you gave us a wrong output file: AFAIU, you gave us the output of "pcanfdtst rx" in "/tmp/pcanfdtst_tx_100" while we asked for "pcanfdtst tx". Please, be careful to give us the output of:
That is, the output of the pcanfdtst application when it writes 100x frames with CAN ID = 0x123 over your 1Mbps CAN bus connected to the CAN channel of your PCAN-PCIe.
Stéphane
$ pcanfdtst tx -b 1M -i 0x123 -n 100 -l 8 /dev/pcan0 > /tmp/pcanfdtst_tx_100
Stéphane
— Stéphane
sorry for the inconvenience, here is the correct file.
Katharina
Katharina
- (7.26 KiB) Downloaded 537 times
- S.Grosjean
Ok, thanks.
Can you redo this but with writing 1.000 frames, please?
Tell us if the program stops by itself or if it must be stopped with ^C.
Do you see these frames on your monitoring software?
After the above command has completed, please give us the output of:
Stéphane
$ pcanfdtst tx -b 1M -i 0x123 -n 1000 -l 8 /dev/pcan0 > /tmp/pcanfdtst_tx_1000
$ cat /proc/pcan
Stéphane
— Stéphane
it did not stop by itself so I had to terminate it.
I did see something on the monitoring software, I also attached a screenshot of that output.
The output of cat /proc/pcan was:
*------------- Release_20171027_n (8.5.1) Jan 29 2018 11:54:57 --------------
*--------------------- 1 interfaces @ major 238 found -----------------------
0 pci -NA- df200000 016 0x0014 00000002 000001f5 00000000 00000001 0x0001
Katharina
Katharina
pcanfdtst_tx_1000.txt
- (35.85 KiB) Downloaded 528 times
- Data_output.PNG (43.43 KiB) Viewed 5044 times
- S.Grosjean
Can you give us the output of:
Please, give us the serial number of that board too.
Everything looks like your board is not given any interrupt to the driver. Please check if the board is well connected into the PCI slot. You could also try to plug it into another one.
Could you test this board in a Windows PC?
You could also check if the transceiver of the board is ok: here is how to do that: http://www.peak-system.com/forum/viewto ... f=120&t=52
Stéphane
$ lspci -d 1c: -vv
Stéphane
— Stéphane
