Post by M.Maidhof » Tue 25. Jun 2013, 15:22
looks ok. Please send the full output of your make process. Check also dmesg for relevant outputs. Please update your PI to the latest version: sudo apt-get update, sudo apt-get upgrade.
mohamed mahmoud
Post by mohamed mahmoud » Wed 26. Jun 2013, 13:17
I updated PI to the latest version, and the problem still exists. Here's the build output:
make[1]: Entering directory `/root/Downloads/peak-linux-driver-7.8/driver'
make[1]: *** No rule to make target `depend'.  Stop.
make[1]: Leaving directory `/root/Downloads/peak-linux-driver-7.8/driver'
*** Host machine kernel version=3.6.11+
*** Driver kernel version=3.6.11
*** Path to kernel sources=/lib/modules/3.6.11+/build
*** use KBUILD=yes
make -C /lib/modules/3.6.11+/build SUBDIRS=/root/Downloads/peak-linux-driver-7.8/driver        EXTRA_CFLAGS="-I/root/Downloads/peak-linux-driver-7.8/driver        -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-headers-3.6.11+'
  WARNING: Symbol version dump /usr/src/linux-headers-3.6.11+/Module.symvers
           is missing; modules will have no dependencies and modversions.
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_main.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_fops.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_fifo.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_filter.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_parse.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_sja1000.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_common.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_usb_core.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_usb.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_usbpro.o
  CC [M]  /root/Downloads/peak-linux-driver-7.8/driver/src/pcan_timing.o
  LD [M]  /root/Downloads/peak-linux-driver-7.8/driver/pcan.o
  Building modules, stage 2.
  MODPOST 1 modules
  CC      /root/Downloads/peak-linux-driver-7.8/driver/pcan.mod.o
  LD [M]  /root/Downloads/peak-linux-driver-7.8/driver/pcan.ko
make[2]: Leaving directory `/usr/src/linux-headers-3.6.11+'
make[1]: Entering directory `/root/Downloads/peak-linux-driver-7.8/lib'
# ln -sf ../driver/pcan.h pcan.h
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
make[1]: Leaving directory `/root/Downloads/peak-linux-driver-7.8/lib'
make[1]: Entering directory `/root/Downloads/peak-linux-driver-7.8/test'
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest   -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest   -lpcan -lstdc++ -DNO_RT
cc src/bitratetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest   -lpcan -DNO_RT
cc src/filtertest.cpp src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o filtertest   -lpcan -lstdc++ -DNO_RT
cc src/pcan-settings.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o pcan-settings   -lpopt -g
make[1]: Leaving directory `/root/Downloads/peak-linux-driver-7.8/test'
Post by M.Maidhof » Thu 27. Jun 2013, 11:21
so here is the output from my Pi:
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ uname -r
3.6.11+
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ make clean
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd  pcan.mod.c
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ make NET=NO PCI=NO PCC=NO ISA=NO DNG=NO PAR=NO
*** use KBUILD=yes
make -C /lib/modules/3.6.11+/build SUBDIRS=/home/mm/peak-linux-driver-7.8/driver        EXTRA_CFLAGS="-I/home/mm/peak-linux-driver-7.8/driver        -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.6.11+'
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_main.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_fops.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_fifo.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_filter.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_parse.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_sja1000.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_common.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_usb_core.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_usb.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_usbpro.o
  CC [M]  /home/mm/peak-linux-driver-7.8/driver/src/pcan_timing.o
  LD [M]  /home/mm/peak-linux-driver-7.8/driver/pcan.o
  MODPOST 1 modules
  CC      /home/mm/peak-linux-driver-7.8/driver/pcan.mod.o
  LD [M]  /home/mm/peak-linux-driver-7.8/driver/pcan.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.6.11+'
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ sudo insmod pcan.ko
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ cat /proc/pcan
*------------- Release_20130131_n (7.8.0) Jun 27 2013 11:07:58 --------------
*--------------------- 1 interfaces @ major 248 found -----------------------
32    usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
please do the same steps on your system. Please do those steps in the \driver directory only.
mohamed mahmoud
Post by mohamed mahmoud » Thu 27. Jun 2013, 12:14
I solved the problem. the file Module.symvers was messing in the kernel-headers. i downloaded it from github then i placed it in /usr/src/linux-headers-3.6.11+, then i re-built the driver and it worked this time. now , i can load the module.
Here's the link where i downloaded Module.symvers:
https://github.com/raspberrypi/firmware ... le.symvers
emilio.munoz
Post by emilio.munoz » Mon 15. Jul 2013, 11:34
Finally I could install the driver. The problem in my case was that at the utsrelease.h located in the folder of the linux-headers was written "3.6.11", so I have to add the "+"
Anyway, now I am having a different problem, because I compiled the kernel and now when I try to install the driver it appers the following error: "can't find /include/linux/version.h"
The thing is that now my kernel version is different, because when I write uname -r I get "3.6.11-cutdown+". I guess this is the problem, but I don't know how to solve it.
thanks for your attention.
Emilio
U.Wilhelm
Post by U.Wilhelm » Tue 16. Jul 2013, 10:58
Have you checked that you have a symbolic link to your header file directory?
See PDF Docu, page 14, section 5.2.1:
Up from kernel version 2.6.x the completely configured
kernel sources for your target system have to be installed. If
it is a standard installation the sources are located under
“/usr/src/linux“ in which this normally is a link e.g. to
“/usr/src/linux-2.6.6“. For every kernel smaller or equal than
2.4.x only the “kernel-headers“ have to be installed. (It's not
wrong to install the complete sources of the target system.)
The kernel-headers are installed if the invocation of “cat
/lib/modules/'uname -r'/build/include/linux/modversions.h“
is ending without an error. (“'uname -r'“ is a placeholder for
the result of the invocation “uname -r“.)
emilio.munoz
Post by emilio.munoz » Wed 17. Jul 2013, 16:42
Yes....that was the problem!! Thanks! Now it works!.
The only thing is that when I try to install a NETDEV driver utility and I compile your driver with
make NET=NETDEV_SUPPORT PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
what I get with cat /proc/pcan command is:
│*n -type- ndev --base-- irq --btr- --read-- --write- --irqs-- -errors- status
│32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
The ndev column should be can0 instead of -NA-. I know that the SocketCAN option is not enabled in the kernel config of the Raspberry PI, but I tried to compile the kernel following some instructions: (http://elinux.org/RPi_CANBus) but it is still not working with the can0 at ndev.
I don't know what I can be doing wrong
U.Wilhelm
Post by U.Wilhelm » Wed 17. Jul 2013, 17:15
You have compiled the CharDev Driver
have you removed the CharDev driver before you try to install the NetDev?
ckeydel
Post by ckeydel » Thu 29. Aug 2013, 12:59
Hi Michael,
I am trying the same thing right now but can't get the kernel module to load. I have a brand new RPi, the latest standard wheezy from the Raspberry Pi foundation, completely updated system and I followed the instructions to the letter. Here is the output of my build:
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ uname -r
3.6.11+
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ make clean
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ make NET=NO PCI=NO PCC=NO ISA=NO DNG=NO PAR=NO
*** use KBUILD=yes
make -C /lib/modules/3.6.11+/build SUBDIRS=/home/pi/install/peak-linux-driver-7.8/driver        EXTRA_CFLAGS="-I/home/pi/install/peak-linux-driver-7.8/driver        -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_main.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_fops.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_fifo.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_filter.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_parse.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_sja1000.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_common.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_usb_core.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_usb.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_usbpro.o
  CC [M]  /home/pi/install/peak-linux-driver-7.8/driver/src/pcan_timing.o
  LD [M]  /home/pi/install/peak-linux-driver-7.8/driver/pcan.o
  MODPOST 1 modules
  CC      /home/pi/install/peak-linux-driver-7.8/driver/pcan.mod.o
  LD [M]  /home/pi/install/peak-linux-driver-7.8/driver/pcan.ko
pi@raspberrypi ~/install/peak-linux-driver-7.8/driver $ sudo insmod pcan.ko
Error: could not insert module pcan.ko: Invalid module format
It looks exactly like yours, except I can't load the module. Any ideas?
Cheers,
Chris
U.Wilhelm
Post by U.Wilhelm » Fri 30. Aug 2013, 08:52
Hi Chris,
i do not see any differnt between the way you did it and how Michael show how to do it.
Have you any news? Solution?
