nagilode
Post by nagilode » Thu 13. Dec 2012, 10:37
Thanks that was the relevant hint. What I did to get it working was:
1. Extract the kernel config
cd <kerneldir>
zcat /proc/config.gz > .config
2. Completely compile kernel (Takes a while if really on raspberry)
make
3. Compile peak driver version 7.7
cd <pcandir>
make KERNEL_LOCATION=<kerneldir> PCI=NO_PCI_SUPPORT
4. Load module
insmod ./driver/pcan.ko
5. Check it
lsmod
>Module Size Used by
>pcan 55776 0
dmesg  | tail
>[522289.664950] pcan: Release_20120726_n (le)
>[522289.664980] pcan: driver config [mod] [isa] [dng] [usb] [net]
>[522289.667153] usbcore: registered new interface driver pcan
>[522289.667220] pcan: major 251.
Thanks a lot for the help. I'll report further if the dongle has arrived.
Post by M.Maidhof » Thu 13. Dec 2012, 10:54
thanks for the info. Yes, please report about your experience with your Raspberry PI board and PCAN-USB. This will also be helpfull for other users of that hardware.
BTW: you compiled our driver for Netdev, so you can´t use the chardev tools like cat /dev/pcanXX or receivetest than. Maybe you should use the chardev interface as a first test, so simply compile the driver with the NET=NO option and load it again.
Post by M.Maidhof » Wed 3. Apr 2013, 19:16
here you will find a step by step instruction on how to install our linux driver on a Raspberry PI with the latest raspbian wheezy with kernel 3.6.11+:
check your kernel version:
mm@raspberrypi ~ $ uname -r
3.6.11+
get the linux headers for 3.6.11+ from here:
wget http://www.niksula.hut.fi/~mhiienka/Rpi ... _armhf.deb
install the headers:
sudo dpkg -i linux-headers-3.6.11+_3.6.11+-2_armhf.deb
get the latest peak-linux driver 7.8 from here:
wget http://www.peak-system.com/fileadmin/me ... 7.8.tar.gz
unpack it:
tar -xzf peak-linux-driver-7.8.tar.gz
build the driver:
cd peak-linux-driver-7.8/
make clean
make NET=NO PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
sudo make install
cd driver
sudo insmod pcan.ko
check that the driver is loaded:
mm@raspberrypi ~/peak-linux-driver-7.8/driver $ cat /proc/pcan
*------------- Release_20130131_n (7.8.0) Apr 1 2013 10:58:08 --------------
*--------------------- 1 interfaces @ major 248 found -----------------------
32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
with cat /dev/pcan32 you will receive data (500k)
with echo "m s 0x11 2 0x22 0x33"> /dev/pcan32 you can transmit data with your Raspberry PI.
raspiBoard
Post by raspiBoard » Wed 19. Jun 2013, 19:51
I'm using a peak-usb can device on a raspberry pi with the last kernel version (3.6.11). I've followed your step by step tutorial and works like a charm. Now, I'm trying to use NETDEV driver utility.
I compiled the driver using those lines
make NET=NETDEV_SUPPORT PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
sudo make install
cd driver
sudo insmod pcan.ko
What I get with cat /proc/pcan command is:
│*n -type- ndev --base-- irq --btr- --read-- --write- --irqs-- -errors- status
│32 usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
The ndev column should be can0 instead of -NA-, so I assume that the driver is not loaded correctly.
The chardev driver works OK but i can't get netdev driver working.
Do you know if netdev driver should work on a raspberry pi? Or maybe I'm doing something wrong?
Thank you in advance,
Toni
Post by M.Maidhof » Thu 20. Jun 2013, 09:32
the SocketCAN option is not enabled in the the kernel config of the Raspberry PI, so you have to call make menuconfig and enable the SocketCAN option, recompile the kernel and load it again. Then you should be able to use the NetDev Interface with your Raspberry Pi and the PCAN-USB.
You will find all needed information on how to recompile the kernel for the Raspberry Pi on the web, please note that the kernel compilation on the Pi will take some hours.
emilio.munoz
Post by emilio.munoz » Tue 25. Jun 2013, 13:41
Dear Sir,
Recently we have adquired a raspberrypi device as well as a PCAN-USB and I am trying to install the drivers. Since I don't know much about Raspbian or even any Linux related stuff is a getting a bit hard to install the drivers.
I followed the instructions that you wrote and everything went fine until I got to write the following ones:
sudo make install
where some errors appeared and I could not do anything else.
PLease, could you tell me what I should do in order to be able to install the drivers?
Thanks for your help and I do apologize any inconvenience.
Post by M.Maidhof » Tue 25. Jun 2013, 14:06
please send us details about the error messages
BTW: without any knowledge of Linux, it will be a hard way for you to work with the Raspberry PI and our drivers...
mohamed mahmoud
Post by mohamed mahmoud » Tue 25. Jun 2013, 14:30
I followed the step by step instructions to build the driver. pcan.ko is generated but when i tried:
insmod pcan.ko
it says:
Error: could not insert module pcan.ko: Invalid module format
given that the kernel version is 3.6.11+ and i downloaded the same packages in the step by step instructions.
Please, could you help me solve this problem?
Post by M.Maidhof » Tue 25. Jun 2013, 14:46
please send the output of uname -r
mohamed mahmoud
Post by mohamed mahmoud » Tue 25. Jun 2013, 15:04
the output of uname -r is :
3.6.11+
