Ubuntu 14.04.5 install PCAN view failed
zapar25059
Post by zapar25059 » Wed 6. Mar 2019, 10:40
Hi.
my platform base is Ubuntu 14.04.5 , kernel version is 4.4.0-31-generic.
now I want to install PCAN view with linux amd64 version. I follow guidence as below command:
$ sudo apt-get install libncurses5
$ sudo dpkg --install pcanview-ncurses_0.8.7-0_amd64.deb
but there is error message while the second command.
here is my output message:
ubuntu14045@ubuntu14045-SOMIK:~$ sudo apt-get install libncurses5
Reading package lists... Done
Building dependency tree
Reading state information... Done
libncurses5 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 461 not upgraded.
ubuntu14045@ubuntu14045-SOMIK:/$ cd /tmp/
ubuntu14045@ubuntu14045-SOMIK:/tmp$ sudo dpkg --install pcanview-ncurses_0.8.7-0_amd64.deb
Selecting previously unselected package pcanview-ncurses:amd64.
(Reading database ... 166795 files and directories currently installed.)
Preparing to unpack pcanview-ncurses_0.8.7-0_amd64.deb ...
Unpacking pcanview-ncurses:amd64 (0.8.7-0) ...
dpkg: dependency problems prevent configuration of pcanview-ncurses:amd64:
 pcanview-ncurses:amd64 depends on libncurses5 (>= 6); however:
  Version of libncurses5:amd64 on system is 5.9+20140118-1ubuntu1.
 pcanview-ncurses:amd64 depends on libtinfo5 (>= 6); however:
  Version of libtinfo5:amd64 on system is 5.9+20140118-1ubuntu1.
dpkg: error processing package pcanview-ncurses:amd64 (--install):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
looks like "Libncurses5" is too old to install PCAN view now. but there is no option with apt-get install newer one.
can anybody help this problem ?
Reason: Inserted code tags for improved readability.
S.Grosjean
Re: Ubuntu 14.04.5 install PCAN view failed
Post by S.Grosjean » Thu 7. Mar 2019, 10:47
Could you please try to install the attached one? This one has been made for trusty.
$ tar -xzf pcanview-ncurses_0.8.7-5_amd64-trusty.tar.gz
$ sudo dpkg -i pcanview-ncurses_0.8.7-5_amd64-trusty.deb
Thanks for your feedback.
(62.7 KiB) Downloaded 309 times
zapar25059
Post by zapar25059 » Mon 11. Mar 2019, 10:09
Hi.
This trusty build is workable for installation.
but it has problem while creating a Tx test. (Rx test is good). I just can see the logs about sending message. but nothing received from my others node.
To prove my client is still working, I try to use transmitest for Tx testing and it is workable.
is there anything that i can provide here for debugging this issue?
(Pictures resized to a "normal" resolution by ADMIN)
S.Grosjean
Post by S.Grosjean » Mon 11. Mar 2019, 11:43
Please give us the output of:
$ cat /proc/pcan
$ lspcan -t -T -i
$ dmesg | grep pcan
Can you do quite the same test with:
$ pcanfdtst tx -p 1000000 -ie 0x7ff -I 8 /dev/pcanusb32
Meanwhile, from another window, type:
$ while :; do clear; lspcan -t -T -s; sleep 1; done
and check whether the number in the "tx" column increases and if the "err" column stays 0.
Finally, can you also please give us the command line that works with transmitest.
Thanks and regards,
zapar25059
Post by zapar25059 » Wed 13. Mar 2019, 11:19
Hi.
message output as below
cat /proc/pcan
*------------- Release_20181116_n (8.7.0) Mar  7 2019 01:04:58 --------------
*--------------------- 1 interfaces @ major 244 found -----------------------
32    usb   -NA- ffffffff 000 0x001c 00000000 00000000 00000000 00000000 0x0000
lspcan -t -T -i
dev name	port	irq	clock	btrs	bus
[PCAN-USB 0]
|_ pcanusb32	CAN1	-	8MHz	500k	CLOSED
dmesg | grep pcan
[  193.206271] pcan: module verification failed: signature and/or required key missing - tainting kernel
[  193.206989] pcan: Release_20181116_n (le)
[  193.206991] pcan: driver config [mod] [isa] [pci] [pec] [dng] [par] [usb] [pcc]
[  193.258731] pcan: PCAN-USB channel device number=255
[  193.258734] pcan: usb device minor 32 found
[  193.258798] usbcore: registered new interface driver pcan
[  193.258811] pcan: major 244.
[  319.960917] pcan: PCAN-USB channel device number=255
[  319.960922] pcan: usb device minor 32 found
[ 3100.165061] pcan: PCAN-USB channel device number=255
[ 3100.165069] pcan: usb device minor 32 found
about pcanfdtest with below command:
1552471808~033981 /dev/pcanusb32 < 000007ff .e...  8 - 00 00 00 00 00 00 00 00
1552471809~034318 /dev/pcanusb32 < 000007ff .e...  8 - 01 00 00 00 00 00 00 00
1552471809~078214 /dev/pcanusb32 > BUS_STATE=ACTIVE   [Rx:0 Tx:0]   -
1552471810~034707 /dev/pcanusb32 < 000007ff .e...  8 - 02 00 00 00 00 00 00 00
1552471811~034914 /dev/pcanusb32 < 000007ff .e...  8 - 03 00 00 00 00 00 00 00
1552471812~035074 /dev/pcanusb32 < 000007ff .e...  8 - 04 00 00 00 00 00 00 00
1552471813~035287 /dev/pcanusb32 < 000007ff .e...  8 - 05 00 00 00 00 00 00 00
1552471814~035577 /dev/pcanusb32 < 000007ff .e...  8 - 06 00 00 00 00 00 00 00
1552471815~035745 /dev/pcanusb32 < 000007ff .e...  8 - 07 00 00 00 00 00 00 00
1552471816~036111 /dev/pcanusb32 < 000007ff .e...  8 - 08 00 00 00 00 00 00 00
1552471817~036447 /dev/pcanusb32 < 000007ff .e...  8 - 09 00 00 00 00 00 00 00
1552471818~036721 /dev/pcanusb32 < 000007ff .e...  8 - 0a 00 00 00 00 00 00 00
1552471819~036977 /dev/pcanusb32 < 000007ff .e...  8 - 0b 00 00 00 00 00 00 00
1552471820~037240 /dev/pcanusb32 < 000007ff .e...  8 - 0c 00 00 00 00 00 00 00
1552471821~037489 /dev/pcanusb32 < 000007ff .e...  8 - 0d 00 00 00 00 00 00 00
1552471822~037675 /dev/pcanusb32 < 000007ff .e...  8 - 0e 00 00 00 00 00 00 00
1552471823~037890 /dev/pcanusb32 < 000007ff .e...  8 - 0f 00 00 00 00 00 00 00
1552471824~038140 /dev/pcanusb32 < 000007ff .e...  8 - 10 00 00 00 00 00 00 00
1552471825~038332 /dev/pcanusb32 < 000007ff .e...  8 - 11 00 00 00 00 00 00 00
1552471826~038650 /dev/pcanusb32 < 000007ff .e...  8 - 12 00 00 00 00 00 00 00
1552471827~038852 /dev/pcanusb32 < 000007ff .e...  8 - 13 00 00 00 00 00 00 00
1552471828~038989 /dev/pcanusb32 < 000007ff .e...  8 - 14 00 00 00 00 00 00 00
^C/dev/pcanusb32 < [packets=21 calls=21 bytes=168 eagain=0]
dev name	port	bus	%bus	rx	%fifo	tx	%fifo	err
[PCAN-USB 0]
|_ pcanusb32	CAN1	CLOSED	-	1	0.00	21	0.00	0
besides, I input below for transmitest from user manual
transmitest transmit.txt -f=/dev/pcanusb32 -b=0x14 -e -n=100
S.Grosjean
Post by S.Grosjean » Wed 13. Mar 2019, 13:28
Everything sounds good. So, did you see the 21 CAN frames written with "pcanfdtst tx" received on the other node?
aamess
Post by aamess » Thu 31. Dec 2020, 22:56
How did you open pcanview-ncurses in terminal please?
Thank you
Snímka obrazovky 2020-12-31 o 23.10.37.png (1017.65 KiB) Viewed 675 times
U.Wilhelm
Post by U.Wilhelm » Sat 2. Jan 2021, 16:51
if you installed all needed files correct, the tool is part of the /usr/bin folder.
Simply change to the /usr/bin folder and check if the applicaton is available by type ls pcan*
If yes you only need to type pcanview and the tool will start.
