PCAN-M.2 CAN errors in combination with a IFM RM9000
mbuijs
Post by mbuijs » Tue 20. Oct 2020, 18:13
I'm using a PCAN-M.2 interface on a Intel NUC7i7DNBE to communicate with a machine over a 500 kbit CAN bus. The CAN bus on this machine has 2 custom boards and 3 IFM RM9000 CANOpen encoders connected, so combined with the NUC there are 6 nodes on the bus. The bus is properly terminated at both ends. On the NUC I have Ubuntu 18.04 installed (kernel 5.4.0-51), I'm using mainline netdev.
As long as the NUC is not connected, the CAN bus communication between the 5 connected nodes works fine, the software running on one of the custom boards can read encoder values and so on and the 2 custom boards can communicate with each other.
As long as the 3 encoders are not connected, the NUC can receive all communication on the bus from the 2 custom boards without any problems. I have not tried transmitting anything from the NUC yet, as I first wanted the bus to work fine with all nodes connected.
When I connect both the encoders and the NUC with the PCAN-M.2 interface, the PCAN-M.2 starts returning error frames as follows:
$ candump -tA -e can0,0~0,#FFFFFFFF
 (2020-10-20 13:14:44.043915)  can0  20000004   [8]  00 04 00 00 00 00 00 63   ERRORFRAME
	controller-problem{rx-error-warning}
	error-counter-tx-rx{{0}{99}}
 (2020-10-20 13:14:44.043916)  can0  20000004   [8]  00 10 00 00 00 00 00 87   ERRORFRAME
	controller-problem{rx-error-passive}
	error-counter-tx-rx{{0}{135}}
 (2020-10-20 13:14:44.050835)  can0  20000004   [8]  00 04 00 00 00 00 00 7F   ERRORFRAME
	error-counter-tx-rx{{0}{127}}
I have attached a full log that I created using candump where I plugin the encoders and unplug them at the end.
When I configure can0 as listen-only, there seems to be no problem and all messages are received.
My problem solving experience while using CAN is limited, I don't really understand what this error means, so I didn't really know where to start looking.
In an attempt to learn something, I tried using the proprietary driver. Unfortunately I shows the same problem, I've attached a trace that I created using pcanview. While using pcanview I also tried different clock speeds, but no improvement unfortunately.
For reference the output of ip link:
$ ip -d -s link show can0
3: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/can  promiscuity 0
    can state ERROR-ACTIVE (berr-counter tx 0 rx 85) restart-ms 100
	  bitrate 500000 sample-point 0.875
	  tq 12 prop-seg 69 phase-seg1 70 phase-seg2 20 sjw 1
	  peak_canfd: tseg1 1..256 tseg2 1..128 sjw 1..128 brp 1..1024 brp-inc 1
	  peak_canfd: dtseg1 1..32 dtseg2 1..16 dsjw 1..16 dbrp 1..1024 dbrp-inc 1
	  clock 80000000
	  0          0          0          1744       1720       0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    RX: bytes  packets  errors  dropped overrun mcast
    85548      14763    0       3537    0       0
    TX: bytes  packets  errors  dropped carrier collsns
    0          0        0       0       0       0
    can state ERROR-WARNING (berr-counter tx 0 rx 127) restart-ms 100
	  clock 80000000
	  0          0          0          1819       1794       0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    87688      15083    0       3537    0       0
    0          0        0       0       0       0
    can state ERROR-PASSIVE (berr-counter tx 0 rx 135) restart-ms 100
	  clock 80000000
	  0          0          0          1834       1809       0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    88580      15238    0       3537    0       0
    0          0        0       0       0       0
pcanview_2020-10-20_1434_plugin.log
(173.11 KiB) Downloaded 196 times
candump_2020-10-20_131405_plugin_plugout.txt
(30.29 KiB) Downloaded 199 times
Re: PCAN-M.2 CAN errors in combination with a IFM RM9000
Post by M.Heidemann » Wed 21. Oct 2020, 08:37
Please check if your CANopen nodes use internal termination and if your bus is over-terminated, perhaps.
Furthermore, does this error also occur if two Socket-Can nodes (one of them being the PCAN-M.2) are communicating with each other?
Please report back to me regarding this.
mbuijs
Post by mbuijs » Thu 22. Oct 2020, 15:39
The bus is properly terminated. As I mentioned in my message there is no problem when the PCAN-M.2 is connected with the 2 custom boards.
This morning I experimented a bit more with the setup, also having an additional RM9000 encoder available for testing. I found the following:
  1. When encoder 1 is connected, the error occurs.
  2. When encoder 2 is connected, the error occurs.
  3. When encoder 3 is connected, the error does not occur.
  4. When encoder 4 is connected, the error does not occur.
  5. When encoders 3 and 4 are connected, the error does not occur.
Then I returned my setup to having encoder 1, 2 and 3 connected as it was before and started trying different bus timing configurations. Nothing seemed to help, until I tried setting the baudrate to 501 kbit:
$ sudo ip link set can0 type can baudrate 501000
    can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 100
	  bitrate 500000 sample-point 0.800
	  tq 400 prop-seg 1 phase-seg1 2 phase-seg2 1 sjw 1
	  clock 80000000
	  0          0          0          0          0          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    17836884   3090436  0       11635   0       0
    301016     40580    0       0       0       0
Using this configuration there are no errors even with the encoder 1 and 2 connected to the CAN bus.
Afterward I also tried other baudrates (502000, 500500, 501500), but none worked without side effects. It seems that either the clock rate of the encoders or the clock rate of the PCAN-M.2 is not accurate. Do you have any suggestion to investigate this on the PCAN-M.2 side?
Post by PEAK-Support » Fri 23. Oct 2020, 08:47
As Marvin wrote - check cabeling, measure termination etc.
This have nothing to do with our card it looks like a local setting of your CANopen Devices (duplicate Node IDs, wrong cabeling, over Terminated etc.). If the Devies are real CANopen Devices, the Standard 500K Bitrate should work.
mbuijs
Post by mbuijs » Fri 23. Oct 2020, 13:06
Today I tried using a PCAN-USB adapter (IPEH-002022) and it didn't show any error. What is the difference between PCAN-USB and PCAN-M.2?
Edit:
So I noticed that the bit timing that is used by PCAN-USB when configured to 500 kbit are the following:
          tq 125 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
          clock 8000000 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
While the PCAN-M.2 defaults to the following:
	  clock 80000000
When I configure the PCAN-M.2 to the same settings, there are no CAN errors either. I used the following commands:
$ sudo ip link set can0 type can tq 125 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
$ ip -d link show can0
	  clock 80000000numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
Post by M.Heidemann » Fri 23. Oct 2020, 14:32
The PCAN-M.2 is a FD-capable device, whereas the PCAN-USB only supports CAN2.0.
Both devices use different CAN-Controllers which have different default configurations for 500kbit/s sp 0.875 under SocketCAN.
As you noticed the same configuration can be applied to the PCAN-M.2 as well in case there is an incompatibility with the default bitrate at that sample-point.
mbuijs
Post by mbuijs » Mon 26. Oct 2020, 10:16
So I think I found the root cause.
  1. When configuring the PCAN-M.2 to 501 kbit, it would choose tq 400 instead of tq 12. There would be no problem in that case.
  2. When changing SJW to 2 instead of the default 1, there seems to be no problem.
  3. When measuring the bit timing using an oscilloscope, I found that the 2 encoders that trigger the CAN errors, apply a bit timing that sums up to 1988 ns. The other boards and the PCAN-USB sum up to 2000 ns, just like the PCAN-M.2.
  4. I believe the combination of the inaccurate encoders with the strict tq of 12 ns and SJW 1 was causing the problem.
I decided to use the PCAN-USB settings (tq 125 ns, SJW 1) on the PCAN-M.2 for now, as I don't have any other CAN FD devices anyway.
