PCAN-USB FD on Linux: Error on trying to run test program, transmitest
Arcon
Post by Arcon » Fri 12. Mar 2021, 09:27
I have installed "PCAN Linux Driver", "PCAN Basic API for Linux" and "PCAN-View for Linux" following the documentation in here.
However, on trying to run the programs in the test directory, I am getting errors.
This is my output for
$ cat /proc/pcan
*------------- Release_20210119_n (8.11.0) Mar 10 2021 11:52:35 --------------
*--------------------- 1 interfaces @ major 510 found -----------------------
32  usbfd   -NA-        0 000 0x001c 00000000 00000000 00000000 00000000 0x0000
And this is my output for
$ uname -a
Linux fliradas 5.4.0-66-generic #74~18.04.2-Ubuntu SMP Fri Feb 5 11:17:31 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
I tried running the test program transmitest as per instruction in the documentation. Here is the output.
$ transmitest transmit.txt -f=/dev/pcanusb32 –b=0x14 –e –n=100
transmitest Version "Release_20150610_n"  (www.peak-system.com)
transmitest comes with ABSOLUTELY NO WARRANTY.     This is free
transmitest: device node="/dev/pcanusb32"
             Only standard frames are sent, init with 500 kbit/sec.
             Data will be read from "–n=100".
transmitest: error at file read: No such file or directory
transmitest: finished (2).
I tried running with only -f option as well. Here is the output.
             Data will be read from "transmit.txt".
transmitest: can't open /dev/pcanusb32
I would like to note that I was able to transmit CAN frame using PCAN-View.
I would greatly appreciate any help in figuring out the cause of the error.
Regards.
Re: PCAN-USB FD on Linux: Error on trying to run test program, transmitest
Post by M.Heidemann » Fri 12. Mar 2021, 09:42
if you are using a PCAN-USB FD, the appropiate device-name would not be "pcanusb32" but "pcanusbfd32" instead.
You can check this via:
ls dev | grep pcan
Example output:
pcan32
pcan-usb_fd
pcanusbfd32
Please check, if that resolved your issue.
Arcon
Post by Arcon » Wed 17. Mar 2021, 08:43
Thank you for the reply.
The device name should indeed have been "pcanusbfd32". However I was getting the error due to something else.
Copying and Pasting the command directly from the pdf manual into the terminal led to the error. The "-" sign for the options
was not copied properly, leading to the error.
The current output for the command
$ transmitest transmit.txt -f=/dev/pcanusbfd32 -b=0x14 -e -n=100
is
transmitest: device node="/dev/pcanusbfd32"
             Extended frames are sent, init with BTR0BTR1=0x0014
transmitest: driver version = Release_20210119_n
transmitest: CAN_Write(): Network is down
transmitest: type            = usbfd
             Serial Number   = 0x00000000
             Device Number   = 0
             count of reads  = 5
             count of writes = 623
             count of errors = 95
             count of irqs   = 14
             last CAN status = 0x001c
             last error      = 0
             open paths      = 6
transmitest: finished (100).
As you can see, the issue now is "CAN_Write(): Network is down".
The other programs in the /test folder are running fine.
I have also tried running programs from the c++ "example" programs for linux in folder "/libpcanbasic" and they are running properly.
Do you know how to solve "Network is down" issue?
Regards.
Post by M.Heidemann » Wed 17. Mar 2021, 13:37
i was unable to reproduce the issue on a correctly configured bus,
However using the wrong bitrate on the receiving end will yield the results
you have shown.
Keep in mind that your command will run transmitest at 1Mbit/s, make sure your receiving node uses the same bitrate.
Do you also have this issue, when you use a different bitrate, for example 500k? (Make sure your receiving node uses 500k as well)
You can try this via:
transmitest transmit.txt -f=/dev/pcanusbfd32 -e -n=100
transmitest will default to 500k if not bitrate is given.
Arcon
Post by Arcon » Thu 18. Mar 2021, 01:31
Hi Marvin,
You were right. My receiving node was not configured correctly (was not 500Kbps)
The program ran without any errors after correcting for the config.
Warm Regards,
Arcon
