Linux Name Resolution (DNS) Failure
nburkitt
Post by nburkitt » Fri 30. Apr 2021, 19:51
Hi.
I'm using a PEAK PCAN-USB FD interface on an embedded device running Ubuntu 18.04 Linux. It works beautifully, but as soon as the device is connected, DNS queries begin to fail. After some research, I've come to believe that this is due to the systemd network service incorporating the CAN bus into the name resolution algorithm.
Obviously this isn't a PEAK issue, but does anyone on the forum have any insight into how to prevent or work around this problem?
-Nick
Re: Linux Name Resolution (DNS) Failure
Post by M.Heidemann » Mon 3. May 2021, 07:58
Hello Nick,
Which driver are you currently using with your PCAN-USB FD?
Are you using the mainline drivers included in the kernel or are you
using the PCAN-Linux driver package?
If you use the latter, we suspect your use the NetDev variant?
Please let us know.
Post by M.Heidemann » Mon 3. May 2021, 10:16
Furthermore,
Usually the CAN interfaces are not set up to handle DNS,
a output for "resolvectl status" would show a CAN-Interface configured like this:
Link 4 (can0)
      Current Scopes: none
DefaultRoute setting: no
       LLMNR setting: yes
MulticastDNS setting: no
  DNSOverTLS setting: no
      DNSSEC setting: no
    DNSSEC supported: no
Please check wether or not the CAN-interface is set in
/etc/systemd via:
find /etc/systemd/ -name "can*"
and
grep -R can0 /etc/systemd/
nburkitt
Post by nburkitt » Mon 3. May 2021, 19:58
Hi Marvin.
Thanks for the response.
I'm using the built-in drivers.
The information returned by "systemd-resolve --status" includes this section:
Link 9 (can0)
       LLMNR setting: yes
      DNSSEC setting: no
For what it's worth, this is identical to the section for eth0, an interface for which name resolution works correctly when the CAN interface is not attached:
Link 2 (eth0)
       LLMNR setting: yes
      DNSSEC setting: no
"find /etc/systemd/ -name "can*"" produces no output.
"grep -R can0 /etc/systemd/" produces no output (other than "grep: /etc/systemd/system/multi-user.target.wants/lm-sensors.service: No such file or directory").
Thanks again,
-Nick
Post by M.Heidemann » Tue 4. May 2021, 09:59
Is the output for
regarding Link2 (Eth0) the same,
if the PCAN-USB FD is not connected?
Please report back to us reagrding this.
nburkitt
Post by nburkitt » Tue 4. May 2021, 18:25
Hi Marvin.
Yes, the output when the PCAN-USB FD is connected is identical to that when it is not connected, except for the addition of the (can0) section. The output for both conditions is below.
PEAK CAN-FD not attached:
# systemd-resolve --status
Global
         DNS Servers: 192.168.0.1
          DNS Domain: attlocal.net
          DNSSEC NTA: 10.in-addr.arpa
                      16.172.in-addr.arpa
                      168.192.in-addr.arpa
                      17.172.in-addr.arpa
                      18.172.in-addr.arpa
                      19.172.in-addr.arpa
                      20.172.in-addr.arpa
                      21.172.in-addr.arpa
                      22.172.in-addr.arpa
                      23.172.in-addr.arpa
                      24.172.in-addr.arpa
                      25.172.in-addr.arpa
                      26.172.in-addr.arpa
                      27.172.in-addr.arpa
                      28.172.in-addr.arpa
                      29.172.in-addr.arpa
                      30.172.in-addr.arpa
                      31.172.in-addr.arpa
                      corp
                      d.f.ip6.arpa
                      home
                      internal
                      intranet
                      lan
                      local
                      private
                      test
Link 3 (sit0)
       LLMNR setting: yes
      DNSSEC setting: no
Link 2 (eth0)
       LLMNR setting: yes
      DNSSEC setting: no
PEAK CAN-FD attached:
Global
                      16.172.in-addr.arpa
                      17.172.in-addr.arpa
                      18.172.in-addr.arpa
                      19.172.in-addr.arpa
                      20.172.in-addr.arpa
                      21.172.in-addr.arpa
                      22.172.in-addr.arpa
                      23.172.in-addr.arpa
                      24.172.in-addr.arpa
                      25.172.in-addr.arpa
                      26.172.in-addr.arpa
                      27.172.in-addr.arpa
                      28.172.in-addr.arpa
                      29.172.in-addr.arpa
                      30.172.in-addr.arpa
                      31.172.in-addr.arpa
                      corp
                      d.f.ip6.arpa
                      home
                      internal
                      intranet
                      lan
                      local
                      private
                      test
Link 9 (can0)
       LLMNR setting: yes
      DNSSEC setting: no
Link 3 (sit0)
       LLMNR setting: yes
      DNSSEC setting: no
Link 2 (eth0)
       LLMNR setting: yes
      DNSSEC setting: no
Additionally, without the PCAN-USB-FD attached, queries via nslookup succeed:
# nslookup google.com
Server:         127.0.0.53
Address:        127.0.0.53#53
Non-authoritative answer:
Address: 172.217.1.238
Address: 2607:f8b0:4007:814::200e
With the PCAN-USB-FD attached, they fail:
Server:         127.0.0.53
** server can't find google.com: SERVFAIL
But if I specify the DNS server to use, they succeed:
# nslookup google.com 192.168.0.1
Server:         192.168.0.1
Address:        192.168.0.1#53
Address: 64.233.177.100
Address: 64.233.177.139
Address: 64.233.177.113
Address: 64.233.177.101
Address: 64.233.177.138
Address: 64.233.177.102
Address: 2607:f8b0:4002:810::200e
Thanks again for your help with this.
-Nick
Post by M.Heidemann » Wed 5. May 2021, 12:08
Hi Nick,
Please check "/etc/systemd/resolved.conf", is any DNS configured?
Do you have a Fallback DNS configured?
Please check this, configure both if necessary and check if that resolved the
issue.
Please report back to us, if this has changed anything for you.
Possibly a service is also handling DNS settings, you might want
to check this for your Distro and if other users experience similar issue (with any plug&play network device)
marvin
nburkitt
Post by nburkitt » Fri 7. May 2021, 18:28
Hi Marvin.
DNS is configured via DHCP. "/etc/systemd/resolved.conf" is effectively empty, which should be correct for that configuration. Remember, name resolution works correctly when the PCAN-FD-USB interface is not attached.
I've tried disabling the Avahi (mDNS/Bonjour/Zeroconf) service, but this had no effect on the problem.
-Nick
Post by M.Heidemann » Mon 10. May 2021, 16:30
Are you able to reproduce this issue,
when another network-adaptor is added instead of the PCAN-USB FD(a usb-wifi dognle, for example)?
Please let us know.
