Linux Update and lost peak_usb driver
milhead
Post by milhead » Fri 4. Jun 2021, 00:41
Hi Forum;
In the past whenever I plug in my PCAN/USB adapter I've normally
$ uname -a
Linux goliath 5.4.0-73-generic #82-Ubuntu SMP Wed Apr 14 17:39:42 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
-----------------End of dmesg output-----------------
[1907399.129682] usb 2-1.5.3: new full-speed USB device number 9 using ehci-pci
[1907399.238671] usb 2-1.5.3: New USB device found, idVendor=0c72, idProduct=000c, bcdDevice=53.ff
[1907399.238675] usb 2-1.5.3: New USB device strings: Mfr=10, Product=4, SerialNumber=0
[1907399.238676] usb 2-1.5.3: Product: PCAN-USB
[1907399.238678] usb 2-1.5.3: Manufacturer: PEAK-System Technik GmbH
[1907399.239663] peak_usb 2-1.5.3:1.0: PEAK-System PCAN-USB adapter hwrev 83 serial FFFFFFFF (1 channel)
[1907399.240161] peak_usb 2-1.5.3:1.0 can0: attached to PCAN-USB channel 0 (device 255)
.. At this point all  my  link command all work and I can setup can0
But I updated Linux on one of my workstations and when I plug in the adapter
$ uname -a
Linux trailtechu3 5.8.0-53-generic #60~20.04.1-Ubuntu SMP Thu May 6 09:52:46 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
[1734620.180141] usb 3-1.4.4.1: new full-speed USB device number 20 using xhci_hcd
[1734620.297590] usb 3-1.4.4.1: New USB device found, idVendor=0c72, idProduct=000c, bcdDevice=54.ff
[1734620.297595] usb 3-1.4.4.1: New USB device strings: Mfr=10, Product=4, SerialNumber=0
[1734620.297597] usb 3-1.4.4.1: Product: PCAN-USB
[1734620.297600] usb 3-1.4.4.1: Manufacturer: PEAK-System Technik GmbH
At this point none of the link commands recognize can0.. It looks to me that there is an automatic step missing (the peak_usb) commands above.
Any ideas would be appriciated!
Re: Linux Update and lost peak_usb driver
Post by M.Heidemann » Fri 4. Jun 2021, 09:00
Is this issue replicable after a reboot?
Furthermore, what's your output for:
ip link ls
and
lsusb
milhead
Post by milhead » Fri 4. Jun 2021, 16:40
$ sudo ip link ls
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
    link/ether 24:be:05:e2:4e:65 brd ff:ff:ff:ff:ff:ff
    altname enp0s25
3: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
    link/ether 24:be:05:e2:4e:64 brd ff:ff:ff:ff:ff:ff
$ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 005: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
Bus 004 Device 004: ID 2109:0812 VIA Labs, Inc. VL812 Hub
Bus 004 Device 003: ID 2109:0812 VIA Labs, Inc. VL812 Hub
Bus 004 Device 002: ID 2109:0812 VIA Labs, Inc. VL812 Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 016: ID 045e:07a5 Microsoft Corp. Wireless Receiver 1461C
Bus 003 Device 020: ID 0c72:000c PEAK System PCAN-USB
Bus 003 Device 009: ID 2109:2812 VIA Labs, Inc. VL812 Hub
Bus 003 Device 007: ID 0cd5:0004 LabJack Corporation
Bus 003 Device 006: ID 2109:2812 VIA Labs, Inc. VL812 Hub
Bus 003 Device 005: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 003 Device 004: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
Bus 003 Device 002: ID 2109:2812 VIA Labs, Inc. VL812 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I get the same thing after a reboot.
Post by M.Heidemann » Mon 7. Jun 2021, 09:09
Apparently you kernel does not provide the necessary drivers,
are you in any way deviating from the mainline-kernel in terms of modules?
In your case you might wanna try to build and install the PCAN-Linux driver Package as NetDev:
http://www.peak-system.com/fileadmin/me ... 2.0.tar.gz
Download the driver, extract the tarball, change into the peak-linux... driver folder:
make NET=NETDEV_SUPPORT
sudo make install
sudo modprobe pcan
Afterwards check if the driver is installed using:
cat /dev/pcan/
If you see your device listed everythin installed properly, you should now be able to get the device up using "ip link set ...", etc.
Please report back to us, if that resolved your issue.
miller.lowe
Post by miller.lowe » Mon 7. Jun 2021, 19:26
I've not made any changes to the default Ubuntu-Mate and am running the same version on both a working and non-working machine. Both machines are dual processor multi-core HP Z280 workstations.
miller@trailtechu3:~/src/peak-linux-driver-8.12.0
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 20.04.2 LTS
Release:	20.04
Codename:	focal
But I have always let the update services run, I see two different kernel versions on two machines. The first works and the second does not.
Working Machine:
$ uname -a
Linux goliath 5.4.0-74-generic #83-Ubuntu SMP Sat May 8 02:35:39 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Non-Working Machine:
$ uname -a
I don't know how the two machines wound up ad different versions.
The pcan driver downloaded and build fine I had to install;
sudo apt install linux-headers
sudo apt install libpopt-dev
After I built the code the make install appears to pass
$ sudo make install
make[1]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/driver'
mkdir -p /usr/local/bin
cp -f udev/pcan_usb_minor_check.bash /usr/local/bin
chmod 744 /usr/local/bin/pcan_usb_minor_check.bash
cp -f udev/45-pcan.rules /etc/udev/rules.d
cp -f udev/blacklist-peak.conf /etc/modprobe.d
chmod 644 /etc/modprobe.d/blacklist-peak.conf
udevadm control --reload-rules
- manually installing pcan under /lib/modules/5.8.0-53-generic/misc...
- Building dependencies...
make[1]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/driver'
make[1]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/lib'
mkdir -p /usr/lib
cp -d lib/* /usr/lib
if [ -d lib32 ]; then \
	mkdir -p /usr/lib32; \
	cp -d lib32/* /usr/lib32; \
fi
mkdir -p /usr/include
/sbin/ldconfig
make[1]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/lib'
make[1]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/test'
cp receivetest transmitest bitratetest filtertest pcanfdtst pcan-settings receivetest_posix transmitest_posix /usr/local/bin
make[1]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/test'
make[1]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic'
make[2]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/pcanbasic'
cp libpcanbasic.so.4.4.2 /usr/lib/libpcanbasic.so.4.4.2
ln -sf /usr/lib/libpcanbasic.so.4.4.2 /usr/lib/libpcanbasic.so.4
ln -sf /usr/lib/libpcanbasic.so.4.4.2 /usr/lib/libpcanbasic.so.0
/sbin/ldconfig
make[2]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/pcanbasic'
make[2]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/pcaninfo'
cp pcaninfo.1.2.0 /usr/local/bin/pcaninfo
make[2]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/pcaninfo'
make[2]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/examples'
make[3]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/examples/python'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/examples/python'
make[3]: Entering directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/examples/c++'
make[3]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/examples/c++'
make[2]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic/examples'
make[1]: Leaving directory '/home/miller/src/peak-linux-driver-8.12.0/libpcanbasic'
But then the modprobe message fails....
$ sudo modprobe pcan
modprobe: ERROR: could not insert 'pcan': Unknown symbol in module, or unknown parameter (see dmesg)
modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe --ignore-install pcan' for module pcan: retcode 1
modprobe: ERROR: could not insert 'pcan': Invalid argument
The end of the dmesg doesn't give me any clues, but I'm not really a kernel/driver guy.
$ dmesg
... Clipped above this...
[59396.602767] kauditd_printk_skb: 23 callbacks suppressed
[59396.602771] audit: type=1400 audit(1622876416.237:35): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=4586 comm="cups-browsed" capability=23  capname="sys_nice"
[70720.384766] perf: interrupt took too long (2557 > 2500), lowering kernel.perf_event_max_sample_rate to 78000
[83154.195648] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled
[83154.271684] Btrfs loaded, crc32c=crc32c-intel
[95412.197157] perf: interrupt took too long (3239 > 3196), lowering kernel.perf_event_max_sample_rate to 61750
[123394.492241] perf: interrupt took too long (4151 > 4048), lowering kernel.perf_event_max_sample_rate to 48000
[145796.333884] audit: type=1400 audit(1622962817.035:36): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=16029 comm="cups-browsed" capability=23  capname="sys_nice"
[158313.335023] perf: interrupt took too long (5219 > 5188), lowering kernel.perf_event_max_sample_rate to 38250
[214254.632035] perf: interrupt took too long (6530 > 6523), lowering kernel.perf_event_max_sample_rate to 30500
[232197.284274] audit: type=1400 audit(1623049219.010:37): apparmor="DENIED" operation="capable" profile="/usr/sbin/cups-browsed" pid=22007 comm="cups-browsed" capability=23  capname="sys_nice"
[267553.266576] can: controller area network core (rev 20170425 abi 9)
[267553.266647] NET: Registered protocol family 29
[267553.270190] can: raw protocol (rev 20170425)
[268010.091526] pcan: module verification failed: signature and/or required key missing - tainting kernel
[268010.091689] pcan: Unknown symbol alloc_canfd_skb (err -2)
[268010.091784] pcan: Unknown symbol open_candev (err -2)
[268010.091868] pcan: Unknown symbol alloc_can_skb (err -2)
[268010.091903] pcan: Unknown symbol unregister_candev (err -2)
[268010.091950] pcan: Unknown symbol can_change_mtu (err -2)
[268010.092006] pcan: Unknown symbol alloc_candev_mqs (err -2)
[268010.092110] pcan: Unknown symbol close_candev (err -2)
[268010.092169] pcan: Unknown symbol can_bus_off (err -2)
[268010.092271] pcan: Unknown symbol register_candev (err -2)
The non-working computer does have an ISOtp driver installed.
If I thought reinstalling Linux would correct the issue I'd do it but am concerned that some later kernel update will just do it again. I'd prefer to get the pcan driver to work without reinstalling. We run this code and PCAN USB devices on probably 20 machines in my division.. If they all start failing after recommended updates I'm going to have a support storm on my hands.
If you have any more suggestions I'll try them.
Miller
Post by M.Heidemann » Tue 8. Jun 2021, 09:44
Please share the output for your make command with us.
Can you elaborate on the iso-tp driver installed on the non working machine?
miller.lowe
Post by miller.lowe » Tue 8. Jun 2021, 19:55
Here is the output of the make
$ make clean all
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd  pcan.mod.c Module.symvers modules.order .cache.mk
rm -f src/*~
rm -rf obj lib obj32 lib32
rm -f src/*~ out/*.o *~ *.so.* *.so
rm -f src/*~ src/*.o ../pcanbasic/src/*~ ../pcanbasic/src/*.o *~ *.so.* *.so pcaninfo.1.2.0 pcaninfo
rm -f *.pyc
*** Host OS Release=Ubuntu v20.04
*** Host machine kernel version=5.8.0-53-generic
*** Driver kernel version=5.8.0-53-generic (5.8.0)
*** Path to kernel sources=/usr/src/linux-headers-5.8.0-53-generic
*** use KBUILD=yes
*** use DKMS=no
*** gcc version=9
make -C /usr/src/linux-headers-5.8.0-53-generic  EXTRA_CFLAGS="-I/home/miller/src/peak-linux-driver-8.12.0/driver -DNO_DEBUG -DMODVERSIONS -DNO_PARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DNO_DONGLE_SUPPORT -DNO_PCCARD_SUPPORT -DNO_NETDEV_SUPPORT -DNO_RT   -Wno-date-time" V=0 modules M=/home/miller/src/peak-linux-driver-8.12.0/driver
make[2]: Entering directory '/usr/src/linux-headers-5.8.0-53-generic'
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_main.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_fops.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_fifo.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_filter.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_parse.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_sja1000.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_common.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_timing.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcanfd_core.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcanfd_ucan.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_usb_core.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_usb.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_usbpro.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcanfd_usb.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_pci.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcanfd_pci.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_pci_spi.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_pciec.o
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/src/pcan_isa.o
  LD [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/pcan.o
  MODPOST /home/miller/src/peak-linux-driver-8.12.0/driver/Module.symvers
  CC [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/pcan.mod.o
  LD [M]  /home/miller/src/peak-linux-driver-8.12.0/driver/pcan.ko
make[2]: Leaving directory '/usr/src/linux-headers-5.8.0-53-generic'
*** Making pcan libraries
*** gcc version: 9
gcc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls  -DPCANFD_OLD_STYLE_API -c src/libpcan.c -o obj/libpcan.o
gcc -shared -Wl,-soname,libpcan.so -o lib/libpcan.so.6 obj/libpcan.o
cd lib/; ln -sf libpcan.so.6 libpcan.so
gcc -DNO_RT -I. -I../driver -fPIC -Wall -Wcast-align -Wredundant-decls  -DPCANFD_OLD_STYLE_API -c src/libpcanfd.c -o obj/libpcanfd.o
gcc -shared -Wl,-soname,libpcanfd.so -o lib/libpcanfd.so.8 obj/libpcanfd.o
cd lib/; ln -sf libpcanfd.so.8 libpcanfd.so
*** gcc version: 9
gcc -DNO_RT -I. -I../lib -I../driver  -g src/receivetest.c src/common.c -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -o receivetest
g++ -DNO_RT -I. -I../lib -I../driver  -g src/transmitest.cpp src/common.c src/parser.cpp -lstdc++ -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -o transmitest
gcc -DNO_RT -I. -I../lib -I../driver  -g src/bitratetest.c src/common.c -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -o bitratetest
g++ -DNO_RT -I. -I../lib -I../driver  -g src/filtertest.cpp src/common.c -lstdc++ -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -o filtertest
gcc -DNO_RT -I. -I../lib -I../driver  -g src/pcanfdtst.c -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -lpthread -o pcanfdtst
gcc -DNO_RT -I. -I../lib -I../driver  -g src/pcan-settings.c -lpopt -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -g -o pcan-settings
gcc -DNO_RT -I. -I../lib -I../driver  -g src/receivetest_posix.c src/common.c -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -lpthread -o receivetest_posix
g++ -DNO_RT -I. -I../lib -I../driver  -g src/transmitest_posix.cpp src/common.c src/parser.cpp -lstdc++ -lpcanfd  -L../lib/lib -Wl,-rpath ../lib/lib -lpthread -o transmitest_posix
*** Making PCANBasic library with FD support (PCAN driver >= 8.0)
*** target=libpcanbasic
*** version=4.4.2
*** PCAN_ROOT=/home/miller/src/peak-linux-driver-8.12.0
*** gcc version=9
mkdir -p out
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c src/libpcanbasic.c -o out/libpcanbasic.o
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c src/pcaninfo.c -o out/pcaninfo.o
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c src/pcanlog.c -o out/pcanlog.o
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c src/pcbcore.c -o out/pcbcore.o
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c src/pcblog.c -o out/pcblog.o
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c src/pcbtrace.c -o out/pcbtrace.o
gcc -fPIC -shared "-O2" -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib   -c /home/miller/src/peak-linux-driver-8.12.0/lib/src/libpcanfd.c -o out/libpcanfd.o
gcc -shared -Wl,-soname,libpcanbasic.so -o libpcanbasic.so.4.4.2 out/libpcanbasic.o out/pcaninfo.o out/pcanlog.o out/pcbcore.o out/pcblog.o out/pcbtrace.o out/libpcanfd.o -lm
ln -sf libpcanbasic.so.4.4.2 libpcanbasic.so
*** Making PCANINFO
*** target=pcaninfo
*** version=1.2.0
*** gcc version=9
gcc src/main.c ../pcanbasic/src/pcanlog.c ../pcanbasic/src/pcblog.c ../pcanbasic/src/pcbtrace.c ../pcanbasic/src/pcbcore.c ../pcanbasic/src/pcaninfo.c /home/miller/src/peak-linux-driver-8.12.0/lib/src/libpcanfd.c -O2 -Wall -Wcast-align -Wcast-qual -Wimplicit  -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wunused -DNO_RT -I../pcanbasic/src -I/home/miller/src/peak-linux-driver-8.12.0/driver -I/home/miller/src/peak-linux-driver-8.12.0/lib  -lm -ldl  -o pcaninfo.1.2.0
ln -sf pcaninfo.1.2.0 pcaninfo
make[3]: Nothing to be done for 'all'.
*** Making PCANBasic C++ examples
*** g++ version=9
*** PCANBASIC_ROOT=../../pcanbasic
g++ -I../../pcanbasic -I/home/miller/src/peak-linux-driver-8.12.0/driver -DNO_RT src/pcanwrite.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcanwrite
g++ -I../../pcanbasic -I/home/miller/src/peak-linux-driver-8.12.0/driver -DNO_RT src/pcanread.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcanread
g++ -I../../pcanbasic -I/home/miller/src/peak-linux-driver-8.12.0/driver -DNO_RT src/pcaneventread.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcaneventread
g++ -I../../pcanbasic -I/home/miller/src/peak-linux-driver-8.12.0/driver -DNO_RT src/pcaneventwrite.cpp -L../../pcanbasic -Wl,-rpath ../../pcanbasic -lpcanbasic -o pcaneventwrite
Apparently I lied about the can-isotp layer, it's not installed at the current time. The one I was using was https://github.com/hartkopp/can-isotp.git but lsmod does not show it.
$ lsmod | egrep 'can|iso'
can_raw                20480  0
can                    20480  1 can_raw
nls_iso8859_1          16384  1
All in all I don't know why the computer has the higher kernel version than the others... Unless you have a better idea I'm going to reinstall Ubuntu-Mate 20.04 LTS and see if that corrects it. I've never had it not 'just work'
Post by M.Heidemann » Wed 9. Jun 2021, 10:41
i clearly stated, that you will have to build the driver as NetDev in order to use SocketCAN.
Please execute:
sudo make uninstall
from the driver directory and use
these commands:
make clean
sudo make install
sudo modprobe pcan
Finally check if the driver is correctly installed:
ip link ls
Please share the results with us.
