usb pcan fd raspberry pi
kubasmyk
Post by kubasmyk » Sat 17. Jul 2021, 15:02
Greetings i have issue with setting it up properly
I have followed this thread
viewtopic.php?f=59&t=3381
this is the output
pi@raspberrypi:~ cat /proc/pcan
*------------- Release_20210505_n (8.12.0) Jul 15 2021 12:47:20 --------------
*--------------------- 1 interfaces @ major 235 found -----------------------
32  usbfd   can0        0 000 0x001c 0000016a 00000000 000000b5 00000000 0x0000
when i try using commands such as
sudo ip link set can0 up type can bitrate 500000 sample-point 0.875
the adapter starts blinking red
with trial and error i managed to get it work with this
sudo ip link set can0 up type can tq 125 prop-seg 6  phase-seg1 7 phase-seg2 2 sjw 1
any idea what I'm doing wrong?
Re: usb pcan fd raspberry pi
Post by M.Heidemann » Mon 19. Jul 2021, 08:11
Can you elaborate on your issue?
What exactly does not work?
Have you actually tested, if the PCAN-USB FD receives/sends messages as intended?
kubasmyk
Post by kubasmyk » Mon 19. Jul 2021, 09:17
Greetings, thank you for response
This command does't work
The other command works but is very cumbersome to use.
Looks like the up link set has problems setting the adapter registers on its own without manually being told exactly every single register.
Is there a way to make it work less cumbersome?
Post by M.Heidemann » Mon 19. Jul 2021, 09:40
Can you please elaborate how exactly the command:
does not work?
Do you get any error message?
Do you not see the expected traffic ,for example using candump?
If you use candump, do you have error-frames active (-e paramter)?
candump can0 -e
How did you test working conditions?
kubasmyk
Post by kubasmyk » Mon 19. Jul 2021, 14:29
Hi, thanks for quick responses.
Im in my test set up i have a F28069m Launchpad microprocessor connected to a PCAN FD USB adapter that sends a periodic keep alive signal on the can bus.
I can see the messages fine apearing in windows 10 through a Pcan-View software. Im running 500kbits no problem and no issues.
I required to write some test code for software acknowledge im working on for the microprocessor so through its easy to write it in linux. So i tried installing the driver for my raspberry pi so can get things working.
I used a mcp2515 module in the past with raspberry pi. It was very straight forward to set up, but i dont have that anymore. It was just a case of typing a bitrate and everything was working " right outside the box".
I have tried the basic command with bitrate. I saw some other people in the forum recomended setting the sample point after bitrate so i though it was going to be straight forward. Sadly it didnt work for me. So i tried manually setting the registers so it started to work. But that is low level stuff and its bit complicated for me to use as I dont exactly know how it all works together inside.
This is not working
pi@raspberrypi:~ $ sudo ip link set can0 up type can bitrate 500000 sample-point 0.875
pi@raspberrypi:~ $ ip -s -d link show can0
45: can0: <NOARP,UP,LOWER_UP> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
    link/can  promiscuity 0 minmtu 0 maxmtu 0
    can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
          tq 12 prop-seg 69 phase-seg1 70 phase-seg2 20 sjw 1
          pcan: tseg1 1..256 tseg2 1..128 sjw 1..128 brp 1..1024 brp-inc 1
          dbitrate 2000000 dsample-point 0.750
          dtq 12 dprop-seg 14 dphase-seg1 15 dphase-seg2 10 dsjw 1
          pcan: dtseg1 1..32 dtseg2 1..16 dsjw 1..16 dbrp 1..1024 dbrp-inc 1
          clock 80000000
          0          0          0          0          0          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    0          0        0       0       0       0
    0          0        0       0       0       0
this is working
pi@raspberrypi:~ $ sudo ip link set can0 up type can tq 125 prop-seg 6  phase-seg1 7 phase-seg2 2 sjw 1
          clock 80000000
          0          32         0          0          0          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    256        32       32      0       0       0
    0          0        0       0       0       0
I have confirmed this is working with the use of
candump can0 -td
Post by M.Heidemann » Mon 19. Jul 2021, 16:04
The command itself works as intended, however apparently
the bit-timing used for 500kbit/s .875 does not seem to match whats on the bus.
You could also try .75 and .80 sample-points, as they are quite common.
We do not know what you other Node on the bus uses exactly, please check the docs
or its configuration.
You should also check, if:
candump -e
provides usable information on what exactly does not work
Please report back to us.
kubasmyk
Post by kubasmyk » Mon 19. Jul 2021, 16:51
0.75 sample works for a bout 3 seconds then halts, it is red even message comes through.
pi@raspberrypi:~ $ sudo ip link set can0 up type can bitrate 500000 sample-point 0.75
 candump can0 -td
 (000.000000)  can0  005   [1]  01
 (000.993284)  can0  005   [1]  01
 (000.993247)  can0  005   [1]  01
^Cpi@raspberrypi:~ ip -s -d link show can0
46: can0: <NOARP,UP,LOWER_UP> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
    can state ERROR-PASSIVE (berr-counter tx 0 rx 136) restart-ms 0
          bitrate 500000 sample-point 0.750
          tq 12 prop-seg 59 phase-seg1 60 phase-seg2 40 sjw 1
          clock 80000000
          0          107432911  0          4          4          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    859463943  107433062 107432915 26      4       0
    0          0        0       0       0       0
0.8 sample doesnt work at all
pi@raspberrypi:~ $ sudo ip link set can0 down
pi@raspberrypi:~ $ candump can0 -td
          bitrate 500000 sample-point 0.800
          tq 12 prop-seg 63 phase-seg1 64 phase-seg2 32 sjw 1
          clock 80000000
          0          108003223  0          5          5          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    864026455  108003376 108003227 30      4       0
    0          0        0       0       0       0
pi@raspberrypi:~ $
candump can0 -e doesnt show error frames for the sample 0.75
pi@raspberrypi:~ $ candump can0 -e
  can0  005   [1]  01
  can0  005   [1]  01
  can0  005   [1]  01
for 0.8 sample it doesn't show anything
kubasmyk
Post by kubasmyk » Mon 19. Jul 2021, 21:30
In my microcontroller I have settings:
Can module cock frequency SYSCLOCKOUT/2 =45Mhz
BRP=5
TSEG1 =14
TSEG2 =3
SJW =2
SBG= Only_falling_edges
SAM=Sample_one_time
Enhanced CAN mode enabled
I have used the calculator to workout the sample time
http://www.bittiming.can-wiki.info/#TMS320
I plugged my clock speed 45Mhz into it
I plugged the target sample time 81%
I plugged SJW 2
The result matched my bitrate of:
500k
BRP
TSEG1
TSEG1
It calculated the sample time to be = 83.3
It also said Number of time quanta = 18
this doesn't work
pi@raspberrypi:~ $ sudo ip link set can0 up type can bitrate 500000 sample-point 0.833
It works with PcanView on windows 10. This makes me believe its not fault of other node.
Hopefully it is the information you requested
I noticed it works when use this to set it. maybe "red herring"
sudo ip link set can0 up type can bitrate 500000 sample-point 0.876
47: can0: <NOARP,UP,LOWER_UP> mtu 16 qdisc pfifo_fast state UP mode DEFAULT group default qlen 10
          tq 250 prop-seg 3 phase-seg1 3 phase-seg2 1 sjw 1
          clock 80000000
          0          246939     0          1          1          0         numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
    1986245    249503   246941  11      2       0
    0          0        0       0       0       0
Post by M.Heidemann » Tue 20. Jul 2021, 10:12
The error counts suggests there are still issues with this config.
have you tried to configure microcontroller for 80% Sample-Point and use
80 % SP on the PCAN side?
As you mentioned the TMS320 series is used here, you could, according to the calculator use the following settings for your microcontroller:
500Kbit/s at 45MHZ -> SP 80%
BRP: 6
TQ: 15
Tseg1: 7
Tseg2: 2
SJW: 2
Does this work as intended?
Also, have you checked termination?
The mcp2515 seems to have internal 120Ohm termination, which if the missing termination is not accounted for also could lead to errors on the bus.
marvin
