just uninstall the driver package and reboot the machine.
The maniline kernel 4.9 already includes the drivers for PCAN-PCIe.
Once everythin is uninstalled and the PC rebooted, check via
ip link ls
ip link ls
robot@robot:~/Downloads/peak-linux-driver-8.12.0$ sudo make -C driver install
make: Entering directory '/home/robot/Downloads/peak-linux-driver-8.12.0/driver'
mkdir -p /usr/local/bin
cp -f udev/pcan_usb_minor_check.bash /usr/local/bin
chmod 744 /usr/local/bin/pcan_usb_minor_check.bash
cp -f udev/45-pcan.rules /etc/udev/rules.d
cp -f udev/blacklist-peak.conf /etc/modprobe.d
chmod 644 /etc/modprobe.d/blacklist-peak.conf
udevadm control --reload-rules
make: *** No rule to make target 'pcan.ko', needed by 'install_module'. Stop.
make: Leaving directory '/home/robot/Downloads/peak-linux-driver-8.12.0/driver'
robot@robot:~/Downloads/peak-linux-driver-8.12.0$ sudo lspci -vvv -d 1c:
0005:01:00.0 Network controller: PEAK-System Technik GmbH Device 0003 (rev 02)
Subsystem: PEAK-System Technik GmbH Device 0005
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 0
Region 0: Memory at 1f40000000 (32-bit, non-prefetchable) [disabled] [size=64K]
Region 1: Memory at 1f40010000 (32-bit, non-prefetchable) [disabled] [size=64K]
Capabilities: [50] Power Management version 0
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [70] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [90] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Capabilities: [100 v1] Vendor Specific Information: ID=0000 Rev=0 Len=00c <?>
ip link ls
$ cd peak-linux-driver-8.12.0
$ sudo make uninstall
sudo lspci -v
Flags: fast devsel
Capabilities: [90] Express Endpoint, MSI 00
Capabilities: [100] Vendor Specific Information: ID=0000 Rev=0 Len=00c <?>
Kernel driver in use: pcan
Kernel modules: pcan
ls -l /dev/pcan*
ls: cannot access '/dev/pcan*': No such file or directory
/etc/modprobe.d$ ls
alsa-base.conf blacklist-framebuffer.conf blacklist-tegra-safety.conf
bcmdhd.conf blacklist-modem.conf iwlwifi.conf
blacklist-ath_pci.conf blacklist-mttcan.conf tegra-udrm.conf
blacklist.conf blacklist-oss.conf
blacklist-firewire.conf blacklist-rare-network.conf
ip link ls
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1
2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 3e:8c:ed:0a:9b:78 brd ff:ff:ff:ff:ff:ff
3: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
link/ether 48:b0:2d:3a:86:90 brd ff:ff:ff:ff:ff:ff
4: l4tbr0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
link/ether 9a:8a:ae:12:94:65 brd ff:ff:ff:ff:ff:ff
5: rndis0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN mode DEFAULT group default qlen 1000
6: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast master l4tbr0 state DOWN mode DEFAULT group default qlen 1000
link/ether 9a:8a:ae:12:94:67 brd ff:ff:ff:ff:ff:ff
7: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
link/ether 34:c9:3d:a2:a2:47 brd ff:ff:ff:ff:ff:ff
8: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
link/ether 02:42:5f:14:80:69 brd ff:ff:ff:ff:ff:ff
9: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN mode DEFAULT group default qlen 1000
link/ether 00:0e:c6:bd:36:11 brd ff:ff:ff:ff:ff:ff
zcat /proc/config.gz | egrep PEAK_
# CONFIG_CAN_PEAK_PCI is not set
CONFIG_CAN_PEAK_USB=m
ip link ls
$ ip link ls
link/ether 56:f1:a9:2f:3f:1f brd ff:ff:ff:ff:ff:ff
link/ether 02:42:dc:cb:61:d9 brd ff:ff:ff:ff:ff:ff
