C++ how to assign a received frame in a variable
elpimous12
Post by elpimous12 » Fri 27. Aug 2021, 09:13
Testing my c++ code, offline...
Without calls to pcanbasic methods, I need to test my other methods, and I'd like to test with this default received frame.
can_frame = [1002404000a005000000170ff230d181400];
But doesn t work!!
Brackets doesn't seems to be the right method?!!
Just need one ex of this variable alimentation.
Thanks all
Vincent
Re: C++ how to assign a received frame in a variable
Post by M.Heidemann » Fri 27. Aug 2021, 09:30
Please use the structure as defined by PCANBasic:
Also you should test with an hardware active,
PCANBasic works closely with the driver, which will require
an active hardware to function as intended.
elpimous12
Post by elpimous12 » Fri 27. Aug 2021, 10:26
Hey, Marvin,
I have this process in my code.
My question is :
What is c++ type of requested msg variable?
Is it data[64]?
Can I request 3rd byte as :
Int byte3 = msg.DATA[2]
from a RECEIVED CANFD message
Post by M.Heidemann » Fri 27. Aug 2021, 10:45
The struct for messages is the same regardless of their direction,
see the PCANbasic.h file:
// Structure definitions
// Represents a PCAN message
typedef struct tagTPCANMsg
    DWORD             ID;      // 11/29-bit message identifier
    TPCANMessageType  MSGTYPE; // Type of the message
    BYTE              LEN;     // Data Length Code of the message (0..8)
    BYTE              DATA[8]; // Data of the message (DATA[0]..DATA[7])
} TPCANMsg;
// Represents a timestamp of a received PCAN message
// Total Microseconds = micros + 1000 * millis + 0x100000000 * 1000 * millis_overflow
typedef struct tagTPCANTimestamp
    DWORD  millis;             // Base-value: milliseconds: 0.. 2^32-1
    WORD   millis_overflow;    // Roll-arounds of millis
    WORD   micros;             // Microseconds: 0..999
} TPCANTimestamp;
// Represents a PCAN message from a FD capable hardware
typedef struct tagTPCANMsgFD
    BYTE              DLC;      // Data Length Code of the message (0..15)
    BYTE              DATA[64]; // Data of the message (DATA[0]..DATA[63])
} TPCANMsgFD;
You can assign the returned byte from the array to an Int, but you'll
have to cast the byte to int.
elpimous12
Post by elpimous12 » Fri 27. Aug 2021, 20:08
Perfect. Thanks Marvin.
You can close.
