PEAK Pcan M2 : raise RuntimeError('Event loop is closed')
elpimous12
Post by elpimous12 » Sun 5. Sep 2021, 20:01
python3.8
ros noetic
Peak can board M2
Hello the team,
I need to use asyncio in my code, and it returns an error after the first query. Any idea ?
Here is my code : https://pastebin.com/ndcbTS59
here is the terminal error : https://pastebin.com/DRjCrz1Z
the main() is ru the first time, and works correctly.
On the second run, errors appear.
Any idea ?
Best regards, the team.
Vincent
Re: PEAK Pcan M2 : raise RuntimeError('Event loop is closed')
Post by M.Heidemann » Mon 6. Sep 2021, 07:43
Hello Vincent,
Thank you for your request.
We are not familiar with python-CAN or ROS and therefore
cannot provide support in that regard.
A bad callback could be due to referencing a class
directly instead of an object of the class, but we have no way
of confirming that's the case with your code.
Please check if this might be the case.
