Queue is empty with peak CAN USB
kiminhan
Post by kiminhan » Thu 21. Apr 2022, 14:52
I am trying to use the peak CAN USB.
Firstly, I installed the driver peak-linux-driver-8.10.0, and PCAN-Basic_Linux-4.3.4.
When I check with pcan View (on windows), CAN signal is visualized on the viewer.
However, when I take CAN signal using the PCANBasic examples, the result is printed
'The receive queue is empty'
Please tell me the problem.
The result of "pcaninfo" at terminal is
PCAN driver version: 8.10.0
  * pcanusb32: (/sys/class/pcan/pcanusb32)
  	- file: /dev/pcan32
  	- dev: "511:32"
  	- dev_name: "/dev/pcan32"
  	- minor: 32
  	- base: 0
  	- irq: 0
  	- adapter_name: "PCAN-USB"
  	- adapter_number: 0
  	- adapter_version: "8.4"
  	- type: "usb"
  	- hwtype: 11
  	- devid: 0x00
  	- ctrlr_number: 0
  	- mass_storage_mode: 0
  	- clock: 8 MHz
  	- nom_bitrate: 500 kBit/s
  	- btr0btr1: 0x1c
  	- init_flags: 0
  	- clk_drift: 0
  	- ts_fixed: 0
  	- nom_brp: 1
  	- nom_sample_point: 0.00%
  	- nom_sjw: 1
  	- nom_tseg1: 13
  	- nom_tseg2: 2
  	- nom_tq: 0
  	- bus_state: Closed / Unknown (0)
  	- rx_error_counter: 0
  	- tx_error_counter: 0
  	- tx_fifo_ratio: 0%
  	- irqs: 754
  	- status: 0
  	- errors: 0
  	- read: 5661
  	- write: 0
  	- TPCANHandle: "PCAN_USBBUS1" (0x051)
And the result of cat /proc/pcan
*------------- Release_20200311_n (8.10.0) Apr 20 2022 16:45:04 --------------
*--------------------- 1 interfaces @ major 511 found -----------------------
32    usb   can0 ffffffff 000 0x001c 0000161d 00000000 000002f2 00000000 0x0000
Reason: Inserted code tags for improved readability
Re: Queue is empty with peak CAN USB
Post by M.Maidhof » Thu 21. Apr 2022, 17:29
please build the driver in chardev mode to be able to use the PCANBasic API (I can see can0 in cat /proc/pcan, which means you have build a Netdev driver). Please also use the latest version 8.14 from our linux website:
kiminhan
Post by kiminhan » Fri 22. Apr 2022, 10:05
Thank you so much Michael ;)
Everything is working well as following your answer.
