I tried the PCAN-USB FD with Windows software. I get great results when I grab the CAN FD messages.
I then tried the SOCKET CAN approach on the Rasberry Pi and logged the captured data using candump can0 command.
CAN FD messages 'seems' to be coming in, but when I try to analyse each CAN FD message Id's, they seem OFF.
This is the information I get from the device from the Rasberry Pi:
pi@raspberrypi:~ $ sudo dmesg | grep peak
[ 11.489868] peak_usb 1-1.2:1.0: PEAK-System PCAN-USB FD v6 fw v3.4.3 (1 channels)
[ 11.498530] peak_usb 1-1.2:1.0 can0: attached to PCAN-USB FD channel 0 (device 4294967295)
[ 11.498809] usbcore: registered new interface driver peak_usb# we need to get CAN setup
sudo ip link set can0 up type can bitrate 500000 dbitrate 2000000 fd on
sudo ifconfig can0 txqueuelen 65536
These are the same settings used when running the Windows app to capture data.
I get a large number of 205 CAN ID - which I don't see in the Windows version:
(1713378957.367098) can0 205##50000000000000000000041FF030300FF0000000000000C5B0000000000000000
(1713378957.387038) can0 205##50000000000000000000041FF030300FF0000000000000D460000000000000000
(1713378957.407097) can0 205##50000000000000000000041FF030300FF0000000000000E610000000000000000
(1713378957.427102) can0 205##50000000000000000000041FF030300FF0000000000000F7C0000000000000000
(1713378957.446859) can0 205##50000000000000000000041FF030300FF00000000000000C70000000000000000
(1713378957.457159) can0 42C##50000000000000000000000000000000000000000000000F20000000000000000
(1713378957.467097) can0 205##50000000000000000000041FF030300FF00000000000001DA0000000000000000
(1713378957.487060) can0 205##50000000000000000000041FF030300FF00000000000002FD0000000000000000Code: Select all
(008791.986000) can0 112##32800100000000000000000000000000000800080708000479000000000000000
(008792.597000) can0 103##32000000000000000000000202000000000000000000000360000000000000000
(008793.059000) can0 202##32000000200000000000000000000000000000000000000259000000000000000
(008793.515000) can0 263##32D8C0000000000000000000B0C10F0000000000000000025C000000000000000
(008793.973000) can0 483##32000000000000000000000000000000080000000000000AE2000000000000000
(008794.430000) can0 65A##32000000000000000000000200000000000000000000000A3A000000000000000
(008795.396000) can0 7A2##32000000000000000000003A2006413830D80000000000CD86000000000000000
(008796.785000) can0 207##3200000000000000000000A000000000000000000000000A53000000000000000
(008797.394000) can0 106##6400000000000000000000000000000440E7003E80007004000000000000000000000007DD00000000000000000000000000000000000004D60000000000000000
(009219.064272) can0 113##32000000000000000000000000000000000000800003FF074F000000000000000
(009219.065272) can0 113##32000000000000000000000000000000000001800003FF074F000000000000000
(009219.066272) can0 201##320000000000004420000000000000000000000000000002A5000000000000000
(009219.067272) can0 201##320000000000008872400000000000000000000000000002A5000000000000000
Something is OFF ... Any tips as to what I am missing
Rasberry Pi 4B with December 2023 release OS
