PCAN-Linux: GCC-12 isn't used when building.
laney
Post by laney » Mon 6. May 2024, 11:16
I am stuck at the same spot EntwB was with his post "Tue 6. Feb 2024, 15:19". Make is using gcc version 11 instead gcc version 12.
I've tried 8.16 driver with patch and also 8.17 driver.
The gcc-12 is installed, i've tried also to restart the system. I'm getting this output no mater what.
*** Host OS Release=Ubuntu v22.04
*** Host machine kernel version=6.5.0-28-generic
*** Driver kernel version=6.5.0-28-generic (6.5.0)
*** Path to kernel sources=/usr/src/linux-headers-6.5.0-28-generic
*** use KBUILD=yes
*** use DKMS=
*** gcc version=11
I am pretty new to linux, do anyone have an idea ?
Re: Patch for peak-linux-driver_8.16 and kernel 6.5.x
Post by M.Heidemann » Mon 6. May 2024, 11:28
Hey Laney,
Please don't hijack someone elses topic,
this makes it next to impossible for anyone to find anything on here.
I split this into a new new topic, don't be alarmed.
As to your question:
Can you confirm gcc12 is installed?
If yes, you can also change the default syslink for gcc so gcc12 is used:
you'll find the syslink gcc in /bin/
you can:
1) remove the current gcc syslink
sudo rm gcc
2) create a new syslink for gcc pointing to gcc12:
sudo ln gcc-12 gcc
3) Try building again.
Please let me know if you were able to build the driver.
laney
Post by laney » Mon 6. May 2024, 11:40
I have used this attribute to force gcc-12:
make CC=gcc-12
It compiles and works...
Re: PCAN-Linux, GCC-12 isn't used when building.
Post by M.Heidemann » Mon 6. May 2024, 11:51
Thanks for letting us know.
- closed -
