pcanview in listen-only does not work
freddy.ben-zeev
Post by freddy.ben-zeev » Fri 14. Jun 2024, 20:29
I'm running pcanview on Ubuntu 20.04. When I run it without "listen only mode", with a pcanview.xmt file (with a couple of messages), it works just fine. But - if I enable in settings (during startup) the listen-only mode, with a different device generating messages, the Rx windows remains empty. When I do the same on the Windows PCAN-View it works just fine.
Any idea how to monitor the messages on my Ubuntu (the Windows system is not always there...)
Freddy
Re: pcanview in listen-only does not work
Post by M.Maidhof » Mon 17. Jun 2024, 10:55
which PCAN hardware do you use? Which driver version is installed? Do you have a third CAN node available which will ack the messages, when you work with pcanview in LO mode? If you have only 2 CAN nodes, where one is in LO mode, all frames will not be acknowledged and the sender will repeat the same message again and again.
Post by M.Maidhof » Mon 17. Jun 2024, 11:04
please also note that in LO mode, pcanview won't send out any frames of your xmt file.
freddy.ben-zeev
Post by freddy.ben-zeev » Fri 21. Jun 2024, 02:28
Hi Michael,
I am using PEAK PCAN-USB adapter. The driver version is 8.15.2 (peak-linux-driver). The pcanview is version "PCANView v0.9.3-2-gd2f361a for pcan driver >= v8.x".
There are a few devices on the bus sending, terminating, and receiving messages. The system is working. I want to use the pcanview just to monitor the activity. And of course that in LO mode it won't send anything - this is the meaning of LO.
As I said - this problem is only on Linux. When I run on Windows PCAN-View it works fine monitoring all the messages.
Freddy
S.Grosjean
Post by S.Grosjean » Fri 21. Jun 2024, 10:52
Could you download the last version of the Linux PCAN driver from https://www.peak-system.com/quick/PCAN-Linux-Driver please?
Running pcanview connected to a PCAN-USB device which is set in LO mode works as it should:
Screenshot from 2024-06-21 10-50-56.png (30.17 KiB) Viewed 15879 times
— Stéphane
freddy.ben-zeev
Post by freddy.ben-zeev » Fri 21. Jun 2024, 18:32
Thanks! It works beautifully!
Freddy
