PCAN-USB FD Driver Installation Error
mtse_27
Post by mtse_27 » Wed 7. Aug 2024, 20:24
Trying to install the PCAN-USB FD Driver, not sure if this also installs the PCAN-USB Pro FD Driver as well.
Using a Debian 11 machine, kernel version is 5.10.216-rt108, x86_64 GNU/Linux.
These are the commands I entered in the konsole:
tar -xzf peak-linux-driver-8.18.0.tar.gz
cd peak-linux-driver-8.18.0
make clean
make NET=NETDEV_SUPPORT
make install
This is the error I'm receiving:
root@AVDeskRT:/home/aviya/Downloads/peak-linux-driver-8.18.0# make install
make[1]: Entering directory '/home/aviya/Downloads/peak-linux-driver-8.18.0/driver'
mkdir -p /usr/local/bin
cp -f udev/pcan_usb_minor_check.bash /usr/local/bin
chmod 744 /usr/local/bin/pcan_usb_minor_check.bash
cp -f udev/45-pcan.rules /etc/udev/rules.d
cp -f udev/blacklist-peak.conf /etc/modprobe.d
chmod 644 /etc/modprobe.d/blacklist-peak.conf
udevadm control --reload-rules
- manually installing pcan under /lib/modules/5.10.216-rt108/misc...
mkdir -p /lib/modules/5.10.216-rt108/misc
cp -f pcan.ko /lib/modules/5.10.216-rt108/misc/pcan.ko
- Building dependencies...
depmod 5.10.216-rt108
make[1]: depmod: No such file or directory
make[1]: *** [Makefile:712: install_module] Error 127
make[1]: Leaving directory '/home/aviya/Downloads/peak-linux-driver-8.18.0/driver'
make: *** [Makefile:98: install] Error 2
How can I fix this error? Please and Thank you!
Re: PCAN-USB FD Driver Installation Error
Post by M.Heidemann » Thu 8. Aug 2024, 08:37
You have a real-time kernel, you will need to read the documentation.
Please see the instructions given for building the driver for rt-kernels:
https://www.peak-system.com/fileadmin/m ... /index.php
