Yes,
exactly.
See chapter 3.1 regarding this!
BR
Marv
Can't install PCAN-view on Ubuntu 24.04.2
Re: Can't install PCAN-view on Ubuntu 24.04.2
christiaanvanarum
Sorry to bother you, but another problem has risen.
I've followed chapter 3.1 from the User Manual, but I can't seem to get chardev working. I keep getting the same error when running. See last rows in the log file.
I've uninstalled, made and installed the source again (as seen in the log), but I still have the same output.
What is going wrong? What can I try?
sudo modprobe pcanI've uninstalled, made and installed the source again (as seen in the log), but I still have the same output.
reinstall-log.txt- (33.05 KiB) Downloaded 24382 times
Try disabling "Secure-boot" (BIOS) that option will not allow unsigned drivers to be loaded,
check if disabling it fixes that behavior.
BR
BR
christiaanvanarum
This fixed the issue! But now i must always boot into unsecure mode in order for pcanview to work?
Yes, we cannot change how Linux handles unsigned drivers unfortunately =/
BR
BR
christiaanvanarum
Ah alright... Well, thanks for the help! At least everything works now.
