Problem setting stable ID for pcan interface
USB to CAN Interface
CarlosMardones
Post by CarlosMardones » Mon 1. Aug 2016, 17:44
I have installed peak_drivers 7.15 and OS Ubuntu 14.04.
I need to use 4 can interfaces and I want to set a persistent ID for all of them.
I want to set a rule to udev with a relation of unique attrs
In /sys/class/net I have can0, can1, can2 and can3.
The attrs that I can read for all are as follow.
udevadm info -a -p /sys/class/net/can0
  looking at device '/devices/virtual/net/can0':
    KERNEL=="can0"
    SUBSYSTEM=="net"
    DRIVER==""
    ATTR{mtu}=="16"
    ATTR{type}=="280"
    ATTR{netdev_group}=="0"
    ATTR{flags}=="0x80"
    ATTR{addr_assign_type}=="0"
    ATTR{dev_id}=="0x0"
    ATTR{gro_flush_timeout}=="0"
    ATTR{iflink}=="5"
    ATTR{addr_len}=="0"
    ATTR{address}==""
    ATTR{operstate}=="down"
    ATTR{carrier_changes}=="0"
    ATTR{broadcast}==""
    ATTR{tx_queue_len}=="10"
    ATTR{dev_port}=="0"
    ATTR{ifalias}==""
    ATTR{ifindex}=="5"
    ATTR{link_mode}=="0"
The rule that I can define is:
SUBSYSTEM=="net", ACTION=="add", KERNEL=="can*",ATTR{iflink}=="5", NAME="privateCan"
The attributes that changes are ATTR{iflink}=="5" and ATTR{ifindex}=="5" but I think that it is an autoincrement value so in the same session the value could be different with unplug/plug peak-can
So, when I try to identify a persisten and different attrs for use its on Udev rules I can´t.
If I run this code against /sys/class/usbmisc/can0 I can read:
 KERNEL=="pcanusb0"
    SUBSYSTEM=="usbmisc"
    DRIVER==""
    ATTR{pcan_hwtype}=="11"
    ATTR{pcan_devid}=="16"
    ATTR{pcan_minor}=="0"
  looking at parent device '/devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb2/2-2/2-2.2/2-2.2:1.0':
    KERNELS=="2-2.2:1.0"
    SUBSYSTEMS=="usb"
    DRIVERS=="pcan"
    ATTRS{bInterfaceClass}=="00"
    ATTRS{bInterfaceSubClass}=="00"
    ATTRS{bInterfaceProtocol}=="00"
    ATTRS{bNumEndpoints}=="04"
    ATTRS{supports_autosuspend}=="0"
    ATTRS{bAlternateSetting}==" 0"
    ATTRS{bInterfaceNumber}=="00"
  looking at parent device '/devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb2/2-2/2-2.2':
    KERNELS=="2-2.2"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{bDeviceSubClass}=="00"
    ATTRS{bDeviceProtocol}=="00"
    ATTRS{devpath}=="2.2"
    ATTRS{idVendor}=="0c72"
    ATTRS{speed}=="12"
    ATTRS{bNumInterfaces}==" 1"
    ATTRS{bConfigurationValue}=="1"
    ATTRS{bMaxPacketSize0}=="16"
    ATTRS{busnum}=="2"
    ATTRS{devnum}=="5"
    ATTRS{configuration}==""
    ATTRS{bMaxPower}=="200mA"
    ATTRS{authorized}=="1"
    ATTRS{bmAttributes}=="80"
    ATTRS{bNumConfigurations}=="3"
    ATTRS{maxchild}=="0"
    ATTRS{bcdDevice}=="1c10"
    ATTRS{avoid_reset_quirk}=="0"
    ATTRS{quirks}=="0x0"
    ATTRS{version}==" 1.00"
    ATTRS{urbnum}=="24"
    ATTRS{ltm_capable}=="no"
    ATTRS{removable}=="unknown"
    ATTRS{idProduct}=="000c"
    ATTRS{bDeviceClass}=="00"
  looking at parent device '/devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb2/2-2':
    KERNELS=="2-2"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{devpath}=="2"
    ATTRS{idVendor}=="0e0f"
    ATTRS{speed}=="12"
    ATTRS{bMaxPacketSize0}=="8"
    ATTRS{busnum}=="2"
    ATTRS{devnum}=="3"
    ATTRS{configuration}=="VMware Virtual USB Hub"
    ATTRS{bMaxPower}=="0mA"
    ATTRS{bmAttributes}=="e0"
    ATTRS{bNumConfigurations}=="1"
    ATTRS{maxchild}=="7"
    ATTRS{bcdDevice}=="0100"
    ATTRS{version}==" 1.10"
    ATTRS{urbnum}=="66"
    ATTRS{idProduct}=="0002"
    ATTRS{bDeviceClass}=="09"
    ATTRS{product}=="VMware Virtual USB Hub"
  looking at parent device '/devices/pci0000:00/0000:00:11.0/0000:02:00.0/usb2':
    KERNELS=="usb2"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{devpath}=="0"
    ATTRS{idVendor}=="1d6b"
    ATTRS{speed}=="12"
    ATTRS{bMaxPacketSize0}=="64"
    ATTRS{authorized_default}=="1"
    ATTRS{busnum}=="2"
    ATTRS{devnum}=="1"
    ATTRS{maxchild}=="2"
    ATTRS{bcdDevice}=="0319"
    ATTRS{serial}=="0000:02:00.0"
    ATTRS{urbnum}=="32"
    ATTRS{manufacturer}=="Linux 3.19.0-25-generic uhci_hcd"
    ATTRS{idProduct}=="0001"
    ATTRS{product}=="UHCI Host Controller"
  looking at parent device '/devices/pci0000:00/0000:00:11.0/0000:02:00.0':
    KERNELS=="0000:02:00.0"
    SUBSYSTEMS=="pci"
    DRIVERS=="uhci_hcd"
    ATTRS{irq}=="18"
    ATTRS{subsystem_vendor}=="0x15ad"
    ATTRS{broken_parity_status}=="0"
    ATTRS{class}=="0x0c0300"
    ATTRS{label}=="usb"
    ATTRS{driver_override}=="(null)"
    ATTRS{consistent_dma_mask_bits}=="32"
    ATTRS{dma_mask_bits}=="32"
    ATTRS{local_cpus}=="ff"
    ATTRS{device}=="0x0774"
    ATTRS{enable}=="1"
    ATTRS{msi_bus}=="1"
    ATTRS{local_cpulist}=="0-7"
    ATTRS{vendor}=="0x15ad"
    ATTRS{acpi_index}=="16777728"
    ATTRS{subsystem_device}=="0x1976"
    ATTRS{d3cold_allowed}=="0"
  looking at parent device '/devices/pci0000:00/0000:00:11.0':
    KERNELS=="0000:00:11.0"
    SUBSYSTEMS=="pci"
    DRIVERS==""
    ATTRS{irq}=="0"
    ATTRS{class}=="0x060401"
    ATTRS{device}=="0x0790"
    ATTRS{enable}=="1"
    ATTRS{msi_bus}=="1"
    ATTRS{subsystem_device}=="0x0790"
  looking at parent device '/devices/pci0000:00':
    KERNELS=="pci0000:00"
    SUBSYSTEMS==""
    DRIVERS==""
I try this solution in a computer without peak-drivers and attrs in /sys/class/net/canX were quite close to the attrs in /sys/class/usbmisc/pcanusbX the definition of rules works but I think that is better have peak-drivers and /sys/class/net/canX attribues completed to custom net name.
Do you think there is any way to "complete" /sys/class/net/canX attributes?
Regards and sorry for my english.
S.Grosjean
Re: Problem setting stable ID for pcan interface
Post by S.Grosjean » Wed 3. Aug 2016, 09:37
Hello Carlos,
There's an easiest way for you to assign a unique name to any "canX" interface handled by pcan 7.15 in netdev mode:
By using the "command line options" when loading the pcan module, you're able to tell the driver to fix the "X" in "canX" with a "device id" you previously have setup in each of your PCAN-USB:
1 - unplug all of your PCAN-USB, unload pcan
$ sudo rmmod pcan
2 - load pcan
$ sudo modprobe pcan
3 - plug one PCAN-USB, then, in the peak-linux-driver-x.y.z directory, run this tool:
$ test/pcan-settings -f=/dev/pcanusb0 -d
This should display the current "device id" of this PCAN-USB. You can change this value into your own one. For example, in order to setup "device id" Y, run:
$ test/pcan-settings -f=/dev/pcanusb0 -d=Y
You can then unplug this PCAN-USB and repeat step 3 for each of the others (be sure to setup the right "device id" to the right PCAN-USB!)
4 - once you're finished with all of your PCAN-USB, then you must unload the current pcan module:
$ sudo rmmod pcan
5 - edit (with root permissions) the file "/etc/modprobe.d/pcan.conf" in order to add the "assign=devid" option the system will use when it will load the pcan module next: simply add this line:
options pcan assign=devid
6 - finally, reload the pcan module:
You should normally find a "canX" interface with "X" = the "device id" you have setup, for each PCAN-USB plugged into your system.
Hope this will help!
Stéphane
— Stéphane
CarlosMardones
Post by CarlosMardones » Thu 4. Aug 2016, 08:59
Hello Stéphane,
Thanks a lot, the solution works really fine. I tested it with pcan and pcan-pro and It solve all my problems.
mizba
Post by mizba » Thu 10. Mar 2022, 04:26
Hi Stéphane,
after setting the device id for multiple peak can USB's, will I still see the new device IDs after I uninstall the pcan module and use it in socketcan mode?
I don't want to use the pcan mode and want to use the socketcan mode instead.
Let me know if there is any other way to set the device id's without installing the pcan driver. Thank you.
Post by M.Maidhof » Thu 10. Mar 2022, 10:25
setting the PCAN-USB device ID is only possible with the pcan-settings tool included in the peak-linux-driver (or use Windows tools). The ID itself is stored in the flash of the device. The kernel SocketCAN driver don't use that hardware device number at the moment.
