I have a Perl program that's running a couple of CAN-servers to interact with a HIL setup. And with the connected Linux machines it's just the case of:
ifconfig -a | grep can
ip link set can0 type can bitrate 250000
ip link set up can0
And then I can reference these CAN-interfaces to my perl program via .ini files:
Port 9921
socketCAN:can0:250
But on the OSX system, the CAN-dongles doesn't even show up with ifconfig -a. I thought I just had to install the drivers from Mac-CAN for it to work. I get the dongles listed as available with the can_moni tool and can send/receive frames manually that way. Are there any solutions to achieving this on Mac? Or am I better off trying to get a ubuntu container running and letting it access the host's devices, i.e the CAN dongles?
PCAN-USB on Mac OS
Re: PCAN-USB on Mac OS
MAC OS is a BSD based hybrid-kernel (XNU) and as far as i am aware, there is no native
SocketCAN implementation for OSX. I have seen solutions by hobbyists on github, but
support will be rather limited for this...
We are not affiliated with MAC-CAN but as far as i am aware MAC-CAN doesn't take the
Socket-based approach, you should check the MAC-CAN docs for more information.
From our end there is no MAC OSX support.
margieortiz
Thanks for your answer. I got it.Hello,
geometry dash scratch
Thanks for your feedback!
BR
- closed -
BR
- closed -
