One of PCAN-Basic-Adapter has the following firmware/driver installed (PEAK Flash):PCAN-USB: Requires a FPGA-based device with firmware version equal to or greater than
3.5.1. Requires a driver version equal to or greater than 4.6.0.
At the time of writing this documentation only PCAN-USB Pro FD, and PCAN-USB FD devices
allow reading the GUID of the device.
Calling Get_Value2013() with PCAN_DEVICE_GUID parameter fails with the error message "Wrong message parameter". of course, the firmware version is outdated.Selected Hardware:
Hardware Name: PCAN-USB
Current Version: 2.8.0
Embedded Hardware:
Firmware Version: 5.4.0
Release Date: 18.04.2024
My question is: Can I get the PCAN_DEVICE_GUID from the PCAN-USB (IPE002022), does the hardware support this? The adapter serial number is : S/N < 190000. Can I retrieve the serial number from the label (102936) programmatically? The parameter PCAN_DEVICE_PART_NUMBER returns just the IPEH-xxx article numbers.
