emsameen
Post
by emsameen » Tue 22. Mar 2011, 13:56
Hello all,
I have Can Bus with the following specifications:
- 2.0B protocol type
- 50 KBaut
it is possible to use the PCAN-Pro for reading this rate(50KBoud) .. as far I know the PCAN-pro is a High speed can reader .. and the 50 Kboud is in the range of Low speed CAN .. is that correct ?!
Thanks in advanced for your reply ..
EMS
- Support
Post
by M.Maidhof » Tue 22. Mar 2011, 14:56
yes its possible to use a 50k CAN Baudrate with PCAN-USB-Pro. Low and Highspeed CAN is related to the used CAN transceiver, but even with a highspeed CAN transceiver 50k will be possible without problems.
