PCAN-Pro Question ..!
High-speed USB 2.0 to CAN/LIN Interface
emsameen
Post by emsameen » Tue 22. Mar 2011, 13:56
Hello all,
I have Can Bus with the following specifications:
  • 2.0B protocol type
  • 50 KBaut
it is possible to use the PCAN-Pro for reading this rate(50KBoud) .. as far I know the PCAN-pro is a High speed can reader .. and the 50 Kboud is in the range of Low speed CAN .. is that correct ?!
Thanks in advanced for your reply ..
EMS
Re: PCAN-Pro Question ..!
Post by M.Maidhof » Tue 22. Mar 2011, 14:56
yes its possible to use a 50k CAN Baudrate with PCAN-USB-Pro. Low and Highspeed CAN is related to the used CAN transceiver, but even with a highspeed CAN transceiver 50k will be possible without problems.
