So I though I made the installation right but still I cannot make the driver work:
when I do:
sudo modprobe pcan
I get:
modprobe: FATAL: Module pcan not found in directory /lib/modules/5.4.0-56-generic
timestamp issue
Re: timestamp issue
can you please post your full installation command history?
Do you have all the required packages installed (see chapter 2.2 of the PCAN-Linux Documentation)?
Please also retry installation as follows, from the driver directory:
Will uninstall previously installed PCAN-drivers
Compile, install and load PCAN-Linux driver in NetDev-mode.
Please report back to me if this was able to resolve your issue.
sudo make uninstall
make clean
make NET=NETDEV_SUPPORT
sudo make install
sudo modprobe pcan
