PPC63
Post
by PPC63 » Thu 5. Sep 2019, 10:09
I have a problem with VBS macro, for send data with multiplexers not have a problem like :
Sub Send_TestMux()
Dim sym
Set sym = SymbolsManager("Ctrl").Item("TestMux")
sym.Multiplexers("Multiplexer1").Send(1)
End Sub
It's okay! But send data without multiplexers like that:
Sub Send_TestNoMux()
Dim sym
Set sym = SymbolsManager("Ctrl").Item("TestNoMux")
sym.Send(1)
End Sub
Does not work. I can't find an example or explanation in the documentation. I suppose that some methods are used depending on the class but I don't see where to find this class...
Thank you for your help,
Paul
PS my SymbolsManager :
[TestMux]
ID=000h
DLC=1
Mux=Multiplexer1 0,0 0
Var=Toto unsigned 0,8
[TestNoMux]
ID=001h
DLC=1
Var=TotoNoMux unsigned 0,1
Post
by PEAK-Support » Fri 6. Sep 2019, 10:59
To send a CAN Frame simple set the Value of ony signal, so the CAN Engine knows what to send:
Dim MySignal
Set MySignal = Signals("TotoNoMux")
MySignal.Value = 120
End Sub
To send the complete Symbol, you need to use the DefaultMultiplexer
Dim sym, mux
Set mux = sym("TestNoMux").DefaultMultiplexer
mux.Send(1)
End Sub
PPC63
Post
by PPC63 » Fri 6. Sep 2019, 14:38
Thank you for your responce !
I wanted to send a frame without data.
Paul
K.Wolf
- Software Development
Post
by K.Wolf » Mon 9. Sep 2019, 16:21
To send a frame without data, set DLC to 0 in your symbol:
And use this (simplified) code from the previous post to send the frame:
SymbolsManager("Ctrl").Item("TestNoMux").DefaultMultiplexer.Send(1)
End Sub
