Is there a way to install NETDEV_SUPPORT socket driver on Redhat 2.6.9.34?
[root@in-ftd-01-ios-01a peak-linux-driver-8.9.0]# make -C driver NET=NETDEV_SUPPORT
make: Entering directory `/root/peak-linux-driver-8.9.0/driver'
*** Making pcan driver in netdev mode
*** Host machine kernel version=2.6.9-34.EL.HAWK0003smp
*** Driver kernel version=2.6.9-34.EL.HAWK0003smp (2.6.9)
*** Path to kernel sources=/lib/modules/2.6.9-34.EL.HAWK0003smp/build
*** use KBUILD=yes
*** gcc version=3.4.3
make -C /lib/modules/2.6.9-34.EL.HAWK0003smp/build EXTRA_CFLAGS="-DLINUX_CAN_RESTART_TIMER -I/root/peak-linux-driver-8.9.0/driver -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNETDEV_SUPPORT -DNO_RT " V=0 modules SUBDIRS=/root/peak-linux-driver-8.9.0/driver
make[1]: Entering directory `/usr/src/kernels/2.6.9-34.EL.HAWK0003-smp-i686'
CC [M] /root/peak-linux-driver-8.9.0/driver/src/pcan_main.o
In file included from include/linux/hrtimer.h:19,
from /root/peak-linux-driver-8.9.0/driver/src/pcan_common.h:166,
from /root/peak-linux-driver-8.9.0/driver/src/pcan_main.c:46:
include/linux/ktime.h:320: error: syntax error before "ktime_after"
include/linux/ktime.h:321: warning: return type defaults to `int'
include/linux/ktime.h:332: error: syntax error before "ktime_before"
include/linux/ktime.h:333: warning: return type defaults to `int'
include/linux/ktime.h: In function `ktime_to_ms':
include/linux/ktime.h:346: error: `MSEC_PER_SEC' undeclared (first use in this function)
