Can't connect to PCAN-LIN config tool via USB-to-Serial
RS-232 to CAN/LIN Interface
stevietee10
Re: Can't connect to PCAN-LIN config tool via USB-to-Serial
Post by stevietee10 » Mon 7. Oct 2019, 14:46
For a reason I cannot explain the new unit has started to connect :-)
using the FTDI adaptor, with RX & TX inverted, see snap attached
output level is 5v active high at the PCAN-LIN RX line
The existing units with a configuration already inside will not connect.
I'll try again with a 12v data signal and let you know how I get on
Steve
using utility 'FT Prog'
FTDI inverted.JPG (56.74 KiB) Viewed 9261 times
PCAN-LIN connected.JPG (72.04 KiB) Viewed 9261 times
stevietee10
Post by stevietee10 » Mon 7. Oct 2019, 15:05
Hello, again..
5v signal from adaptor TX line converted to 12v
snap one shows 12v level pulses on the line when PCAN-LIN unit NOT connected
snap two shows this signal being reduced (clamped internally) when PCAN-LIN unit IS connected.
So at the moment, i can connect to new unit but not units previously used i.e. have a .pclin configuration installed and units running, indicated by blinking LED's
Any ideas as to how to access these units greatly appreciated.
Thank you
Steve
12v pulses, PCAN-LIN unplugged
snap1 12v.jpg (79.35 KiB) Viewed 9260 times
5v pulses, PCAN-LIN connected
snap2 5v.jpg (53.09 KiB) Viewed 9260 times
Post by M.Maidhof » Mon 7. Oct 2019, 16:36
a RS232 interface uses positive and negative voltages. So please use an USB2Serial module, as linked in my previous post. This will work out of the box.
BTW: we also offer a USB-RS232 Adapter (FDTI Chip Version), ordering number: IPFH-000101, price 18.-Euro (not available in the webshop, but can be ordered by email)
stevietee10
Post by stevietee10 » Wed 9. Oct 2019, 12:11
Hi Michael
We are now able to reliably connect to a new unit and a 'previously used' unit.
I'm accepting that one unit I have done a lot of testing with now seems to be faulty.
I'm happy to now call this issue 'closed'.
Thank you for your assistance and patience.
We got there eventually :)
Best wishes
Steve
Post by M.Maidhof » Wed 9. Oct 2019, 14:43
Hi Steve,
thanks for the feedback. It will also be possible to repair the defective PCAN-LIN device. Contact us by email (support@) to discuss all further details.
