Is it possible to send messages with the buttons on the display?
J.Dirks
PCAN Mini display
Re: PCAN Mini display
the buttons can only be used to exit the scene or cycle trough a list of scenes.
It is only possible to send a list of predefined messages when you enter or exit a scene, or send a predefined list of messaged cyclic while the scene is active (e.g. request data from a sensor)
Gunnar Bohlen
Gunnar Bohlen
Hello, how can one send a predefined list of messaged cyclic with the buttons?
Thank you.
Thank you.
Reason: Removed full quote of preceding post.
sending messages via button is not supported by the firmware.
-You can send a list of messages ONCE when a scene ist started. (e.g. initialise transmisson of sensor values from other can modules)
-You can send a list of messages CYCLIC while the scene is active (.g. request data from other modules)
-You can send a liste of messgaes ONCE when the scene is terminated. ( e.g. disable transmission of sensor values from other CAN modules)
Regards, Gunnar Bohlen
