connect a pcan-usb to a low speed can network ???
USB to CAN Interface
lacazet2k
Post by lacazet2k » Tue 18. Feb 2020, 09:41
Is it possible to connect a pcan-usb to a low speed can network ..
or do you need to use a PCAN-TJA1054 bus tranceiver ?
It seems the data comming from the ecu is viewable in pcan-view when no termination resistors are used.
tks
Re: connect a pcan-usb to a low speed can network ???
Post by PEAK-Support » Tue 18. Feb 2020, 10:00
if you want a corect layer 1 signal you need a TJA1054 Bus Transceiver and do not work with the HighSpeed Transceiver which is used in the PCAN-USB.
Maybe you could read some frames but it is random if it works or not - it is a differnet Layer 1.
