Mixed 3.3V and 5V CAN transceivers possible?
PCI Express to CAN Interface
abaldur
Post by abaldur » Mon 27. Apr 2020, 10:23
Hi
I'm using the PCAN-PCI Express board for communication with a 3.3V CAN bus.
The PCAN-PCI Express uses the NXP PCA82C251 CAN transceiver which is 5V as far as I can see.
Will this cause any issues with reliability on the network?
Anything to be especially aware of?
Best Regards,
abaldur
Re: Mixed 3.3V and 5V CAN transceivers possible?
Post by M.Heidemann » Mon 27. Apr 2020, 12:01
The PCAN-PCIe use a High Speed compatible Transceiver (ISO 11898-2).
Please check if the transceiver of the 3.3 V CAN bus is compatible with ISO 11898-2 as well.
We do not know of any issues regarding this if both transceivers are ISO 11898-2 compliant.
abaldur
Post by abaldur » Mon 27. Apr 2020, 13:02
Hi Marvin
Thanks for the quick reply.
My 3.3V CAN transceiver happens to be ISO 11898-2 compatible.
So I will assume that things to work together :)
Best Regards,
abaldur
