The new added parameters cannot found in java samples.
Hi, I am new to use PCAN-Basic API in java. There are three new TPCANParameters added in the new version 4.4.0. PCAN_FIRMWARE_VERSION, PCAN_AVAILABLE_CHANNELS_COUNT, and PCAN_AVAILABLE_CHANNELS. But I didn't find the corresponding parameter in the "TOCANParameter.java" file. Do you know what should I add to make these three parameters work?
Re: The new added parameters cannot found in java samples.
Do you use Windows or LINUX PCAN-Basic API? Looks like these Parameters are not implemeted in the latest update of the Java package
Please send us a short E-Mail with the used OS Version (Windows/Linux) to support[at]peak-system.com - we will answer ASAP
