I'm using the PCAN-USB Pro FD. I've tried to use it on the Ubuntu OS but had to move back to Windows, because of better software and no LIN drivers.
On Windows 10 I've used PCAN-view for a few months without any problem, but now I have to use the PLIN-view and I've found two things.
1) Every time I switch on my PC, I can see the CAN LEDS are flashing while LIN LEDS are off. After long research I've found I can run Peak-Drivers 4.2.0 from the Windows Apps and Functions Settings tab and click Repair. Then finally I see both LEDS flashing. It is all because of a Device Manager not running, which is running only for PCAN... I attach proper screenshots. It's annoying to have to do it every time...
2) If I use PLIN in slave mode and try to add a new frame as Publisher, but I do not change the checksum type to Enhanced/Classic a message occures that the checksum couldn't be used. It's ok. Than I choose e.g. Enhanced checksum and a error window occurs. I can click continue and use the PLIN-view correctly, but the error box is annoying too.
PLIN-view bugs
PLIN-view bugs
PLIN_ERROR.txt
- (5.91 KiB) Downloaded 37 times
- PLIN4.PNG (27.5 KiB) Viewed 462 times
- PLIN3.PNG (9.41 KiB) Viewed 462 times
- PLIN2.PNG (14.95 KiB) Viewed 462 times
- PLIN1.PNG (11.73 KiB) Viewed 462 times
- PLIN.PNG (35.41 KiB) Viewed 462 times
Re: PLIN-view bugs
1. Please download our PEAK System Analysis Tool from here. Start the analysis tool on your Windows 10 system with all features enabled and then send us the analysis file to support@peak-system.com.
2. Thank you for the notice, this seems to be an issue. We will investigate it.
Best regards
M.Riedl
Best regards
M.Riedl
