PCAN Router-FD 03_TIMER_IO Example
Locked
blbus
Post by blbus » Tue 8. Dec 2020, 03:59
I am testing the VSC tool chain - downloaded latest package from site. Examples 01_ROUTING and 02_EEPROM load and make fine, but the example 03_TIMER_IO (unmodified) has error with uint32_t type not defined. I've tried to work around but am having issues, and of course, this is the example of interest to me.
The following:
uint32 error.PNG (27.61 KiB) Viewed 4962 times
Re: PCAN Router-FD 03_TIMER_IO Example
Post by M.Heidemann » Tue 8. Dec 2020, 11:00
This issue is due to intellsense not finding a definition for "uint32_t",
The exampe will still compile as its all properly resolved by the compiler.
You can mitigate this Intellisense-beheaviour by adding the defintion, for example in you "main.c" underneath the "includes":
typedef __uint32_t uint32_t;
This should resolve the issues with intellisense regarding this.
Please report back to me regarding this.
blbus
Post by blbus » Tue 8. Dec 2020, 13:53
Thank you. That was a quick fix, and is much appreciated.
~Brad
Post by M.Heidemann » Tue 8. Dec 2020, 13:56
Thank you for your feedback!
-closed-
Locked
