Convert old project for new DLP-DevPack
Universal CAN Converter
JohnM
Post by JohnM » Wed 30. Dec 2020, 00:32
I'm trying to import an old PCAN project into the new Visual Studio Code IDE.
I tried taking a new example "01_ROUTING" and running "SetPath_for_VSCode" and then manually adding the source and header files into the appropriate folders I need but I could not "Make All" successfully.
I get an error in "Linking: example_can.elf" about an "undefined reference".
I fixed this by manually modifying the "Makefile" to include the additional source files:
# List C source files here which must be compiled in ARM-Mode.
# use file-extension c for "c-only"-files
CSRCARM += $(SRC_FOLDER)/main.c
CSRCARM += $(SRC_FOLDER)/can_user.c
CSRCARM += $(SRC_FOLDER)/systime.c
Shouldn't the "SetPath_for_VSCode" do this for me?
Will there be anything else I need to modify for my project for the source/header files I need?
Re: Convert old project for new DLP-DevPack
Post by PEAK-Support » Wed 30. Dec 2020, 10:26
normally you do not have to change any part of your code if you use the new ARM package vor Visual Studio Code.
If you have unzip the package on your PC, copy your Project Folder in a Subfolder of the used Hardware (for example d:\Entwicklung\ARM_based_HW\Hardware\PCAN-Router\ )
If you have copied your complete prooject in a folder in this subfolder, run the SetPath_for_VSCode.vbs again, so that the needed settings for your project will be created (".vscode" Directory)
The run VSCode. Open the Folder (your project main folder) and use in the main menue "Terminal - Run Task" - select make clean - then make all.
