RTNETLINK answers: Operation not supported for listen-only
tkutscha
Post by tkutscha » Mon 10. Apr 2017, 21:30
I'm getting an error when trying to put one of the PCAN adapters into listen-only mode:
Here's what I've don:
- loaded the Peak Linux drivers 8.3.1, compiled for "netdev" mode
- Used "pcan-settings -f=/dev/pcanusb# -d 42"
- edited the /etc/modprobe.d/pcan.conf file options to "options pcan assign=devid"
Here is my /proc/pcan file:
*------------- Release_20170214_n (8.3.1) Apr 10 2017 12:11:37 --------------
*--------------------- 3 interfaces @ major 245 found -----------------------
32    usb  can42 ffffffff 042 0x001c 00000000 00000000 00000000 00000000 0x0000
33  usbfd  can45 ffffffff 045 0x001c 00000000 00000000 00000000 00000000 0x0000
34  usbfd  can46 ffffffff 046 0x001c 00000000 00000000 00000000 00000000 0x0000
After rebooting, I can now use "ip link" to set the bitrate:
root@vulcan-slicer-2:/etc/modprobe.d# ip link set can42 type can bitrate 1000000
However, I cannot put the PCAN-USB into listen only mode:
root@vulcan-slicer-2:/etc/modprobe.d# ip link set can42 type can listen-only on
I've seen in a different message that "ip link" is only supported in the default LINUX driver, not the custom Peak driver. I need the Peak driver for the unique device ids. How would you recommend I put the device into listen-only mode for sniffing the CAN bus? Will I have to use "chardev" mode with the pcanfd_init() function?
Thanks for your time,
Tim
Re: RTNETLINK answers: Operation not supported for listen-on
Post by M.Maidhof » Tue 11. Apr 2017, 14:21
this option is not available with the peak-linux-driver at the moment. You have to switch to the kernel driver to use the "listen-only" mode under Linux.
tkutscha
Post by tkutscha » Tue 11. Apr 2017, 17:05
Hi Michael,
Thanks for your reply. I'll attempt to use the chardev Linux driver for listen-only mode because I need control over the device-IDs that are only present in the Linux driver.
Cheers,
Tim
adeboever
Re: RTNETLINK answers: Operation not supported for listen-only
Post by adeboever » Wed 6. Jan 2021, 16:57
Is there any update on this? I am having the same issue trying to use listen-only with socketcan with peak-linux-driver 8.9.3
Adam
adeboever
Post by adeboever » Wed 6. Jan 2021, 18:10
The release notes for 8.6.0 mentions CTRL_MODE_LISTEN, is this the same thing as the iproute2 "listen-only" flag?
"netdev: fixed usage of CTRLMODE_LISTEN_ONLY and _FD_NON_ISO socket-CAN flags"
Post by M.Heidemann » Thu 7. Jan 2021, 15:49
Is this issue also replicable with the current Version 8.10.2?
http://www.peak-system.com/fileadmin/me ... 0.2.tar.gz
Can you also provide us with the output for:
uname -a
adeboever
Post by adeboever » Thu 7. Jan 2021, 22:11
Hi Marvin,
I installed the latest driver 8.10.2 and had the same issue.
$ uname -a
Linux 5.4.79-v7l+ #1373 SMP Mon Nov 23 13:27:40 GMT 2020 armv7l GNU/Linux
Note this is running on a raspberry pi 4 with PCAN-Chip usb Pro FD.
Is there another more permanent way to enable listen only mode in the kernel, before bringing up the device?
Adam
Post by M.Heidemann » Fri 8. Jan 2021, 13:53
Hello Adam,
Please contact us via email regarding this issue:
adeboever
Post by adeboever » Fri 8. Jan 2021, 14:01
Done.
Thanks.
