J2534 call trace via shim about how the channel is set up and the exchange:
0.000s ++ PTOpen(*NULL*, 0x070AE760)
returning DeviceID: 81
3.067s 0:STATUS_NOERROR
3.067s ** PTReadVersion(81, 0x18F45F30, 0x18F45F88, 0x18F460E8)
Firmware: 4.5.3.505
DLL: 2.0.6.91
API: 04.04
3.068s 0:STATUS_NOERROR
3.068s ++ PTConnect(81, 6:ISO15765, 0x00000000, 500000, 0x18F54348)
returning ChannelID: 1358954502
3.166s 0:STATUS_NOERROR
3.166s ** PTIoctl(1358954502, 10:CLEAR_MSG_FILTERS, 0x00000000, 0x00000000)
3.166s ** PTIoctl(1358954502, 9:CLEAR_PERIODIC_MSGS, 0x00000000, 0x00000000)
3.166s ** PTIoctl(1358954502, 7:CLEAR_TX_BUFFER, 0x00000000, 0x00000000)
3.166s ** PTIoctl(1358954502, 8:CLEAR_RX_BUFFER, 0x00000000, 0x00000000)
3.166s ++ PTStartMsgFilter(1358954502, 3:FLOW_CONTROL_FILTER, 0x0F3FD618, 0x0F3FA300, 0x0F402B40, 0x18F542D8)
Mask[ 0] 6:ISO15765. 5 bytes. TxF=0x000000c0
TxFlags: 6:ISO15765_FRAME_PAD 7:ISO15765_ADDR_TYPE
\__ ff ff ff ff ff
Pattern[ 0] 6:ISO15765. 5 bytes. TxF=0x000000c0
\__ 00 00 06 12 f1
FlowControl[ 0] 6:ISO15765. 5 bytes. TxF=0x000000c0
\__ 00 00 06 f1 12
returning FilterID: 421575160
3.166s << PTReadMsgs(1358954502, 0x0A30C024, 0x0A30C020, 1)
read 0 of 100 messages
3.168s 9:ERR_TIMEOUT
3.168s >> PTWriteMsgs(1358954502, 0x0A30C024, 0x0A30C020, 100)
Msg[ 0] 6:ISO15765. 7 bytes. TxF=0x000000c0
\__ 00 00 06 f1 12 3e 01
sent 1 of 1 messages
3.168s 0:STATUS_NOERROR
3.168s << PTReadMsgs(1358954502, 0x0A30C024, 0x0A30C020, 1000)
read 1 of 1 messages
Msg[ 0] 1458.339606s. 6:ISO15765. Actual data 5 of 5 bytes. RxS=0x00000009
RxStatus: 0:TX_MSG_TYPE 3:TX_INDICATION
\__ 00 00 06 f1 12
Msg[ 0] 1458.437944s. 6:ISO15765. Actual data 6 of 6 bytes. RxS=0x00000000
\__ 00 00 06 12 f1 7e
3.267s 0:STATUS_NOERROR
3.267s >> PTWriteMsgs(1358954502, 0x0A30C024, 0x0A30C020, 100)
\__ 00 00 06 f1 12 1a 80
3.267s << PTReadMsgs(1358954502, 0x0A30C024, 0x0A30C020, 1000)
Msg[ 0] 1458.438780s. 6:ISO15765. Actual data 5 of 5 bytes. RxS=0x00000009
\__ 00 00 06 f1 12
Msg[ 0] 1458.467896s. 6:ISO15765. Actual data 65 of 65 bytes. RxS=0x00000002
RxStatus: 1:START_OF_MESSAGE
\__ 00 00 06 12 f1 5a 80 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3.296s 0:STATUS_NOERROR
3.296s << PTReadMsgs(1358954502, 0x0A30C024, 0x0A30C020, 1000)
Msg[ 0] 1458.487479s. 6:ISO15765. Actual data 65 of 65 bytes. RxS=0x00000000
\__ 00 00 06 12 f1 5a 80 00 00 08 51 70 16 00 02 00 10 58 59 20 11 07 13 08 08 02 30 41 4c 4a 03 03 01 00 00 00 00 00 04 73 12 77 30 10 36 36 30 30 38 39 5a 4d 30 30 30 38 39 5a 4d 30 41 41 4c 4a 43
3.316s 0:STATUS_NOERROR
3.316s -- PTDisconnect(1358954502)
3.408s 0:STATUS_NOERROR
3.408s -- PTClose(81)
3.410s 0:STATUS_NOERROR
Here is an example J2534 log from a different device for the same exchange, note how 0x80 is set every time in RX Flags:
0.000s ++ PTOpen(*NULL*, 0x08BE22F8)
returning DeviceID: 1
6.366s 0:STATUS_NOERROR
6.367s ** PTReadVersion(1, 0x0FEB83F0, 0x0FEB8708, 0x0FEB8760)
Firmware: 1.16.4769
DLL: 1.02.4798 Jun 13 2016 17:16:24
API: 04.04
6.367s 0:STATUS_NOERROR
6.367s ++ PTConnect(1, 6:ISO15765, 0x00000000, 500000, 0x0FECD4D0)
returning ChannelID: 3
6.368s 0:STATUS_NOERROR
6.369s ** PTIoctl(3, 10:CLEAR_MSG_FILTERS, 0x00000000, 0x00000000)
6.369s 0:STATUS_NOERROR
6.369s ** PTIoctl(3, 9:CLEAR_PERIODIC_MSGS, 0x00000000, 0x00000000)
6.370s 0:STATUS_NOERROR
6.370s ** PTIoctl(3, 7:CLEAR_TX_BUFFER, 0x00000000, 0x00000000)
6.370s ** PTIoctl(3, 8:CLEAR_RX_BUFFER, 0x00000000, 0x00000000)
6.371s ++ PTStartMsgFilter(3, 3:FLOW_CONTROL_FILTER, 0x08C3D3B8, 0x08C3E4C0, 0x08C439E8, 0x0FECD460)
\__ ff ff ff ff ff
\__ 00 00 06 12 f1
\__ 00 00 06 f1 12
returning FilterID: 0
6.372s 0:STATUS_NOERROR
6.373s << PTReadMsgs(3, 0x1CB8A024, 0x1CB8A020, 1)
6.375s 16:ERR_BUFFER_EMPTY
6.378s >> PTWriteMsgs(3, 0x1CB8A024, 0x1CB8A020, 100)
6.478s 9:ERR_TIMEOUT
6.478s ** PTGetLastError(0x0FEB8708)
ERR_TIMEOUT
9:ERR_TIMEOUT
6.481s >> PTWriteMsgs(3, 0x1CB8A024, 0x1CB8A020, 100)
6.513s 0:STATUS_NOERROR
6.513s << PTReadMsgs(3, 0x1CB8A024, 0x1CB8A020, 1000)
Msg[ 0] 1322.405278s. 6:ISO15765. Actual data 0 of 5 bytes. RxS=0x00000089
RxStatus: 0:TX_MSG_TYPE 3:TX_INDICATION 7:ISO15765_ADDR_TYPE
\__ [00] [00] [06] [f1] [12]
6.520s 0:STATUS_NOERROR
6.520s << PTReadMsgs(3, 0x1CB8A024, 0x1CB8A020, 1000)
Msg[ 0] 1322.434175s. 6:ISO15765. Actual data 0 of 5 bytes. RxS=0x00000082
RxStatus: 1:START_OF_MESSAGE 7:ISO15765_ADDR_TYPE
\__ [00] [00] [06] [12] [f1]
6.542s 0:STATUS_NOERROR
6.542s << PTReadMsgs(3, 0x1CB8A024, 0x1CB8A020, 1000)
Msg[ 0] 1322.453765s. 6:ISO15765. Actual data 65 of 65 bytes. RxS=0x00000080
RxStatus: 7:ISO15765_ADDR_TYPE
6.561s 0:STATUS_NOERROR
