PCAN-USB X6 Socket CAN Passive Mode
a.yuzva
Post by a.yuzva » Wed 12. May 2021, 16:03
Is it possible to set PCAN-USB X6 into passive mode using the socket(netdev from Linux mainline kernel) driver, or is it only possible with chardev driver (compiled from peak website)?
Re: PCAN-USB X6 Socket CAN Passive Mode
Post by M.Heidemann » Wed 12. May 2021, 16:16
To confirm:
Do you mean by "passive mode" listen-only, so no interaction with the bus
apart from reading?
a.yuzva
Post by a.yuzva » Wed 12. May 2021, 19:21
To confirm:
apart from reading?
Hi Marvin,
Correct, listen only.
Thank you,
Andriy
Post by M.Heidemann » Fri 14. May 2021, 09:29
Yes, you can with the "listen-only" paramenter:
sudo ip link set canx up type can bitrate 100000 listen-only on
Please see:
