PCAN_ERROR_ILLMODE
Forum for the PCANBasic .NET Assembly Beta-Package containing
the PCANBasic-Assembly developed in .NET-Standard.
Matthias
PCAN_ERROR_ILLMODE
Post by Matthias » Tue 18. May 2021, 16:31
I have a problem concerning the following error code: Driver object state is wrong for the attempted operation (PCAN_ERROR_ILLMODE).
I am relatively new to programming so I don't know exactly wether this problem is due to any missing file/driver or an error in the code.
I am using the PCAN_USB and I used the attached code from the example of the documentation.
I would be grateful if someone could tell me what to do.
My code with the Erro Message (in german)
Re: PCAN_ERROR_ILLMODE
Post by M.Heidemann » Wed 19. May 2021, 07:39
Do you have the PCAN-Drivers including PCANBasic installed?
https://www.peak-system.com/quick/DrvSetup
Please report back to us regarding this
Matthias
Post by Matthias » Thu 27. May 2021, 09:07
thank You for the fast reply.
Unfortunately this was not the issue, the drivers were already installed.
Are there perhaps any other possibilities for the upcoming error?
Matthias
Post by M.Heidemann » Thu 27. May 2021, 09:18
Please check the following:
- Do you have the device intialized with another software, for example PCAN-View?
- Do you have local PCANBasic DLLs? Does the behaviour also occur, when the local DLLs are removed?
Please report back to us regarding this.
Matthias
Post by Matthias » Thu 27. May 2021, 11:27
after deinstalling the drivers and reinstalling them again, and also after reincluding the dlls + restarting the PC, the error disappeard.
I am very grateful for your fast support.
Matthias
cobra_ltc
Post by cobra_ltc » Wed 22. Sep 2021, 22:37
I ran into the exact situation. I'm not able to run PCANBasicExample.exe from either Win32 or x64 folders. I did try renaming the local PCANBasic.dll files, but the results were identical. I uninstalled/reinstalled the 4.2.3 PEAK-Drivers, but the results were the same. I didn't have any other software competing for the PCAN HW (USB) at the time I ran the test. I am able to use the PcanView, so I know the HW works.
I get the same error message whether the drivers are installed or not. SO, it appears that they are "not really installed" for me?!
Anything else I could try to remedy this?
cobra_ltc
Post by cobra_ltc » Wed 22. Sep 2021, 23:19
IGNORE - It started working after a second computer restart.
U.Wilhelm
Post by U.Wilhelm » Mon 18. Oct 2021, 09:27
thy for teh feedback - topic closed
