Hello everyone,
I was trying to get the information regarding the currently available hardware by using the library function GetAvailableHardware() in VB but it seems some problem that I do not understand.
Here is my code and error message:
- Removed by Admin -
Error: -Removed by Admin-
But the same function works on my friend's computer with the same version of the necessary drivers and PCAN Developer 4 library. What could be the problem? Any help would be highly appreciated.
Problem with GetAvailableHardware function
Reason: Please do not share code for a proprietary API in this forum, thank you.
Re: Problem with GetAvailableHardware function
As a first step:
You should check the version of your PCAN-Developer 4 package against
the one which is used by your friend,
the function "GetAvailableHardware" was introduced in version 4.2.0 of PCAN-Devloper 4/PCAN-API 4.
For further support, please contact our support via email, please reference your PCAN-Developer 4 license-ID:
As a first step:
