which method to use for deleting slave responses to specific frame previously set by LIN_SetFrameEntry() (using PLIN-Basic.dll using PCAN-USB Pro FD)? I expect, the data response set by this method can be changed by new call of this method, is it right?
Thank you in advance.
Aleš
Info from Admin: ** Topic moved to PLIN API **
PLIN - Delete frame after LIN_SetFrameEntry()
Re: PLIN - Delete frame after LIN_SetFrameEntry()
If you are mean the PLinApi.dll, that is right.
You can also use LIN_SetFrameEntry again to disable the response by first setting the Direction property of the dependent TLINFrameEntry to dirDisabled.
You are welcome.
M.Riedl
You are welcome.
M.Riedl
