Linux Update and lost peak_usb driver
Re: Linux Update and lost peak_usb driver
Yes, but it outputs errors:
modprobe: ERROR: could not insert 'pcan': Operation not permitted
modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe --ignore-install pcan' for module pcan: retcode 1
modprobe: ERROR: could not insert 'pcan': Invalid argument
Thanks for the quick feedback.
Please check if secureboot is enabled by your bios,
it will prevent unsigned drivers (like the PCAN-Linux driver) from loading.
Disable it and reboot, the driver should load automatically afterwards.
Disable the secureboot works! Thanks!M.Heidemann wrote: ↑Tue 7. Sep 2021, 13:30Thanks for the quick feedback.
Thanks for the feedback!
BTW, do you have a more detail user manual for pcanview (Linux version). It's a bit confusing how to set up the connection.
Hello John,
You can use the Help menu of PCAN-View Linux to
get more information.
There is no additional manual for PCAN-View Linux.
