Not able to connect PCAN-USB FD within Docker Image
CAN FD Interface for High-Speed USB 2.0
OmarAA
Post by OmarAA » Mon 11. Oct 2021, 01:27
Hello all,
I am using PCAN-USB FD in order to publish some sensor information within ROS2 framework utilizing the docker image ade from https://autowarefoundation.gitlab.io/au ... n-ade.html
I get the following error at initialization:
PCAN_ERROR_ILLOPERATION: An operation is not allowed due to the current configuration
When I try the same code within a normal c++ project and run it outside the ade environment it works fine and receives the sensor information.
Any hints why such behaviour happens when running inside a docker image?
The example of used code is below:
#include <pcanbasic/PCANBasic.h>
bool PCAN_Interface::initialize(){
	TPCANStatus result;
	char strMsg[256];
	TPCANBitrateFD bitrate;
	bitrate = "f_clock_mhz=24, nom_brp=3, nom_tseg1=5, nom_tseg2=2, nom_sjw=1, data_brp=2, data_tseg1=4, data_tseg2=1, data_sjw=1";
	result = CAN_InitializeFD(PCAN_USBBUS1, bitrate );
	if (result != PCAN_ERROR_OK){
		CAN_GetErrorText(result, 0, strMsg);
		std::cout << strMsg << std::endl;
		return false;
	else	{
	    	std::cout << "PCAN-USB was initialized" << std::endl;
		return true;
int main(int argc, char *argv[]){
		PCAN_Interface pcan;
 		pcan.initialize();
Re: Not able to connect PCAN-USB FD within Docker Image
Post by M.Heidemann » Mon 11. Oct 2021, 08:32
Please understand that we do not support docker environments,
however we can give suggestions what you might want to check:
- Please check if the PCAN-interface is used by any application outside the container
at the given time
- Please check if the interface is recognized as intended (cat /proc/pcan)
- Make sure the same hardware is used, as not all PCAN-Interfaces support FD (The same error message
would be thrown if you try to initialize FD bitrates with non FD hardware)
Please share your findings with us.
OmarAA
Post by OmarAA » Tue 12. Oct 2021, 11:55
Thank you for your help.
1- I am not sure if there is a definite way to do it. But if I try to uninitialize first I get (A PCAN Channel has not been initialized yet or the initialization process has failed).
Another method is to check the output of:
grep PEAK_ /boot/config-`uname -r`
outside the docker:
CONFIG_CAN_PEAK_PCIEFD=m
CONFIG_CAN_PEAK_PCI=m
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_CAN_PEAK_PCMCIA=m
CONFIG_CAN_PEAK_USB=m
inside the docker:
grep: /boot/config-5.4.0-88-generic: No such file or directory
2 - cat /proc/pcan: it detects the PCAN-USB as needed inside and outside the docker environment
*------------- Release_20210928_n (8.13.0) Oct  3 2021 02:48:46 --------------
*---------------------- [mod] [isa] [pci] [pec] [usb] -----------------------
*--------------------- 1 interfaces @ major 510 found -----------------------
32  usbfd   -NA-        0 000 0x0014 00000001 00000000 00000001 00000000 0x0000
3- Same hardware is used (same host PC and PCAN-USB FD), it is worth mentioning that CAN_Initialize(PCAN_USBBUS1, Baudrate) also throws the same PCAN_ERROR_ILLOPERATION error inside the docker environment
I will keep you updated if I find any solution to it.
Omar
