could not insert 'pcan': Exec format error
I have the same problem as here:
viewtopic.php?t=6585&sid=46c6c9cae0daf8 ... 0e878443ff
However, it seems there are two things usually causing this problem:
1. Secure boot being enabled (which I have it disabled)
2. Mismatch between installed kernel headers and actual kernel version (which mine says both are 5.13.0-28-generic)
I have tried 8.13.0 and 8.14.0, and have gotten it to work on other machines before. Is there anything else that can cause this or something I am missing?
Re: could not insert 'pcan': Exec format error
can you please share some more details like output of the make process, uname -a, used pcan hardware type and which kind of PC you are using?
Sorry, lost track of this post.
This was happening on a very specific kernel version for Ubuntu 20.04 that I think there was some mismatch in the headers for when I updated to it. It was a very repeatable error, but then 2 days later another kernel upgrade happened and then everything built and installed and worked as normal.
ok, most likely it was a kernel header mismatch.
I need to use secure boot for my application.
osboxes@ThinkPad-P51-Ubuntu-Lab:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
I have the same problem. 'sudo modprobe pcan' results in this:
osboxes@ThinkPad-P51-Ubuntu-Lab:~$ sudo modprobe pcan
[sudo] password for osboxes:
modprobe: ERROR: could not insert 'pcan': Operation not permitted
modprobe: ERROR: ../libkmod/libkmod-module.c:990 command_do() Error running install command 'modprobe --ignore-install pcan' for module pcan: retcode 1
modprobe: ERROR: could not insert 'pcan': Invalid argument
I spent the last 8 months working on this application. It was working fine, but now it is broken.
How do I fix this, specifically?
Bob Willard
Release: 20.04
Codename: focal
Bob Willard
in that case you have to sign the pcan kernel module for your Ubuntu 20.04 system. Please use google for more details on how to sign a kernel module.
It works now. Thanks for the prompt response Michael.
I can now 'modprobe pcan' and the module gets loaded, but the device files are not created:
- missing_devices_files.png (116.05 KiB) Viewed 6917 times
which PCAN interfaces are connected to that system?
