RP1210C INI issue on v4.0.1.280
RP1210 Development Package and RP1210 Connectivity to PEAK CAN Interfaces
kiran.vaidya
Post by kiran.vaidya » Tue 26. Apr 2022, 18:05
I've installed RP1210C compliant driver using all-in-one installer - 'PEAK-Drivers 4.3.0 Installer'.
While I was testing RP1210 capabilities, I found 'C:\Windows\PEAKRP32.ini' did not have anything listed under 'Devices' section. Could you please help with it?
Below is snap from .ini file:
;PEAK-System Technik GmbH - RP1210C Vendor INI File
; Author: PEAK-System, K. Wagner Rivas
; Date: December 06, 2018
; Version: 3.0
; Website: http://www.peak-system.com
; Email: support@peak-system.com
; Keyword: RP1210C
[VendorInformation]
Name=PEAK-System PCAN Adapter
Address1=Otto-Roehm str. 69
City=Darmstadt
State=Hessen
Country=Germany
Postal=64293
Telephone=0049-6151-817320
Fax=0049-6151-817329
VendorURL=http://www.peak-system.com
MessageString=PCANRP32_MSG
ErrorString=PCANRP32_ERR
TimeStampWeight=1000
AutoDetectCapable=No
Version=3.0
RP1210=C
DebugLevel=0
DebugFile=c:\\PEAK_RP1210_Debug.txt
DebugMode=1
DebugFileSize=1024
NumberOfRTSCTSSessions=1
CANFormatsSupported=3,4,5
J1939FormatsSupported=1,2,5
J1939Addresses=1
CANAutoBaud=TRUE
ISO15765FormatsSupported=1,2
Devices=
Protocols=10,20,30
; Devices
; Protocols
[ProtocolInformation10]
ProtocolString=CAN
ProtocolDescription=CAN Network Protocol
ProtocolSpeed=125,250,500,1000,Auto
ProtocolParams=
Devices=
[ProtocolInformation20]
ProtocolString=J1939
ProtocolDescription=SAE J1939 Protocol
ProtocolParams=
Devices=
[ProtocolInformation30]
ProtocolString=ISO15765
ProtocolDescription=ISO15765 Vehicle Protocol
ProtocolSpeed=125000,250000,500000,1000000,Auto
ProtocolParams=
Devices=
Re: RP1210C INI issue on v4.0.1.280
Post by K.Wagner » Wed 27. Apr 2022, 07:57
RP1210 devices are configured using the control panel applet from PEAk-System, PEAK-Settings (formerly called PEAK-CPL). This application makes the necessary entries in the INI file. Check the PCAN-RP1210 documentation, chapter 3.4, for more information.
Here how it looks using the old version of the applet, PEAK-CPL:
RP1020 devices configuration using PEAK-CPL
Here how it looks using the new version of the applet, PEAK-Settings:
RP1020 devices configuration using PEAK-Settings
