ginson
Post
by ginson » Mon 9. May 2022, 10:24
I am using PEAK USB 6 channel on a dual boot Ubuntu 18.04LTS.
I am using peak-linux-driver-8.14.0 and PCAN-Basic_Linux-4.6.0 API
The output of command
shows following output
CONFIG_CAN_PEAK_PCIEFD=m
CONFIG_CAN_PEAK_PCI=m
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_CAN_PEAK_PCMCIA=m
CONFIG_CAN_PEAK_USB=m
But command
returns nothing.
Installation of PEAK drivers all done as per the README.txt given in the driver zip file. There was no errors while installation peak driver and API's
Please let me know, if I am missing something.
- Support
Post
by M.Maidhof » Mon 9. May 2022, 10:36
please post the output of "cat /proc/pcan" and "ip a". Did you supply the PCAN-USB X6 with the the necessary supply voltage?
stanhausc
Post
by stanhausc » Mon 9. May 2022, 14:41
Hi, the same here.
- aaaaaaa.png (115.53 KiB) Viewed 4199 times
- Support
Post
by M.Maidhof » Mon 9. May 2022, 15:44
looks like you did not load the driver after the build process with "sudo modprobe pcan"
ginson
Post
by ginson » Tue 10. May 2022, 09:00
M.Maidhof wrote: ↑Mon 9. May 2022, 10:36
Hi Michael,
Thanks for the prompt response.
I didnot supply the necessary voltage. After supplying the voltage it worked.
Cheers!!
