Yes, as written by email, please always use the latest available firmware and driver versions, if you have such problems.
But please also accept that we first need to find out if it is a software or hardware based problem. If you were able to reproduce the problem with PCAN-View, we could be sure the problem is driver/PC/firmware related. And the used workstation with XEON CPU is not the typical "PC" which is used with those cards...so step by step and and try to work together with us next time instead of writing that my tips are "nonsense"...I also know about such problems related to apps which uses other hardware at the same time which causes BSODs and reboots....
